There are many ways to put a picture in a post. This is a How-To on how to use FEP's image attachments to upload images from your computer and place them exactly where you want to in your post.
First, look for the Insert Image icon. If you're posting a new thread, or have chosen the 'Go Advanced' reply option, it'll be here:
If you're posting a reply using the quick reply option at the bottom of a page, it'll be here:
The Insert Image pop-up will appear. Make sure you select 'From Computer' so the pop-up will look like this:
Then, click the button that says 'SELECT FILES.' At this point, you only want to select the images you want in that particular spot in the post. But, we'll get into repositioning the image(s) later. When you click 'SELECT FILES', another window will pop-up allowing you to browse to where you have your desired images stored on your computer. You'll see the file(s) listed in the pop-up, and the button choices at the bottom of the pop-up will change slightly as seen here:
When you're satisfied with the image(s) you have selected to be put into the post, click the middle button that says 'UPLOAD FILE(S).' You'll see the following notation in your post editing box that looks like this:
And that'll get you a thread/post that looks like this one!
If you decide you want to move stuff around, you can just select/copy/paste the ATTACH tags (with their brackets, of course) and the number between them and put that in the desired position. I just copy/pasted the first set of ATTACH tags and the attachment number here and it did this:
Ta-daaaaa!
