I did everything they said to do on several sites and when the car is on the pedal sinks to the floor. I'm afraid to leave my street like that to do the 40 MPH test. The idle goes up when the pedal is pressed too. When the car is off the pedal is in the middle and feels normal. It's acting like the booster is leaking air but it was fine before this conversion.
Lets review:
Hardware is installed correctly and the e-brake works fine.
The soft lines and banjo bolts had to be modified to go from the calipers to the existing lines.
Removed the guts from the front part of the proportioning valve and cap it.
Installed the new Willwood proportioning valve in the proper location and it's wide open right now.
Bleed the brakes. Several times. There is fluid in the calipers.
Help me out guys. Am I missing a step? What did I do wrong?
I'm going to find a brake shop that can make a hard line from the caliper to the existing hard lines. But that won't cause the pedal to go to the floor
