Finally got the block to the machine shop, found some interesting information while measuring out the cylinder bores. Bores measure at 3.820 which would convert to .040 over. My pistons are "factory" ford stamped pistons E3ZE-6110-C4A, on the dome of the piston they are stamped 1.02 (mm) (.040) - Some of the older techs at work said on some of the 2.3t cars they had problems with trashing pistons and the engines would come in and the dealership would send the blocks out for machine work and use ford OE oversized pistons.
My main question is this, my rings were trashed (hence the rebuild) and my bore is perfectly fine in all cylinders just needs honed, and my pistons that are ford forged OE 1.02mm, are fine. So, I am just in need of rings. The OE ford turbo rings seem to be the cream of the crop, but I know they have dried up, especially in an oversize. Seems like the next "best thing" is the CP's ring/piston set from bo or stinger, but honestly 630 bucks for pistons isn't in my plans at the moment, but if its a must, i will.
I found these rings, and these are about the only ones I found that i think will work. I'm in need of opinion (ring materials, and will they hold up to 20/22psi, and be reliable)
http://www.napaonline.com/Catalog/Ca...0MM_0203585213
Its a moly ductile top ring and a chrome second ring in the e441k sets for the 2.3's
Thanks all!
Sent from my Desire HD using Tapatalk 2
