On the 88-91 EEC electrical diagram herein, what mean exactly "→ ignition run circuit" and "to ignition switch". (Center of the diagram)
Top left, #30 what mean NDS ?
Top right, what mean " ↓to ignition run"
Thanking you
Thanking you
'67 7R01C146513
'79 9F03F323753
'81 AF02YJ51305
Neutral Drive Switch (NDS) is the same position you put the key in for Key on Engine Off (KOEO), in other words the ignition key position in the middle of off and engine start.
#30 refers to PIN 30 on the main connector to the EEC4 computer. In this case, PIN 30 goes to Neutral Drive Switch, aka the Neutral Safety Switch. The switch that is engaged when you press the clutch pedal to the floor before you actually start the car.
'86 Mustang GT T-Top, 5-lug Cobra brake swap done
'96 Mustang Cobra 302rwhp 296rwtq, Sold and missed
'11 Mustang GT/CS, Traded and will be missed
'13 Taurus SHO, Performance Pack, hit and run, totalled
'17 Fusion Sport, Livernois tune, Steeda CAI, Steeda Rear Swaybar, Big Mouth Ram Air, GFB+ valve, Steeda Catch can, TTR FMIC (Garrett Core)
This would be a wire from the ignition switch that has power with the key in the run position.ignition run circuit
The red/blue wire gets power from the ignition switch in the start position. the red/green gets power from the ignition switch in the run position.to ignition switch
This is for a car with an idiot light. The light is connected to an ignition switch power source in the run position. The ECU provides the ground when the vehicle isn't running.↓to ignition run
Dave
1983 Capri RS Turbo
1981 Black Magic 400 c6
93 F-250 351 5sp 4x4
Thank you Dave and 86GTdriver !
One more question, to what refer the world "ignition switch" ? Is it different of the ignition key ?
'67 7R01C146513
'79 9F03F323753
'81 AF02YJ51305
On Fox Chassis cars the ignition switch is located lower on the steering column than the key lock. There is a linkage that connects the lock to the switch and activates the switch. While you are in there, take a good look at the ignition switch. They are known to separate and can cause all kinds of gremlins including burning a car to the ground.
Dave
1983 Capri RS Turbo
Thanx Dave !
'67 7R01C146513
'79 9F03F323753
'81 AF02YJ51305
You are welcome.
Dave
1983 Capri RS Turbo
