Well, that doesn't help the process now does it.
There are issues with installing the 87-93 dashes in the Four Eyes, but it can be and has been done. I am not a big fan of the look, but we won't get into that here.
From the sounds of it, have you considered trying to find a donor car that you could pull all the parts off you need. That may be the better solution as the individual parts will add up quickly and all the misc parts that you need might drive you crazy. What you are trying to do is ambitious, but can also be very daunting if you haven't had a lot of experience disassembling and reassembling these cars.
Another option you might seriously consider would be an aftermarket wiring harness. I am a fan of Ron Francis Wire Works and their kits. Their stuff is top notch and I have installed them in about a dozen cars or so over the years. In fact, my Pace Car uses one of their kits and my 84 RS will be getting one too. The nice thing about Ron Francis is that you can order the correct pigtails for your ignition switch, turn signal switch, hazard switch, etc. so it makes the install much easier. You will still need to have some of the specific connectors for tail lights and some other parts, but most of those are available aftermarket or with a JY trip. Ron Francis also offers a kit now with a remote fuse panel that makes it even easier to install in our Fox Body cars. The wiring kit comes with great directions and great tech support and can be done over a couple weekends and you will have a fully wired car.
Take a look at their site and see what you think.
http://www.ronfrancis.com/
If you have questions or want to discuss things in more detail, send me a PM and we can get in touch over the phone if you like.
Trey
