Results 1 to 2 of 2
    New User
    Feb 2014
    St. Albans, Vermont
    Default 1987 lx 5.0 not sparking
    Hey Folks Please chime in if you have any ideas. Bought a 1987 LX 5.0 T Top beast sittin' under a tree for a long time. I'm trying to bring this beast back to life. I added a fresh gal of gas, ck'd the wires and plugs, bugged the coil out, replaced the TFI module but no spark. I then ck'd the six fusible links all seam ok. Turns over great. Pulled #5 plug no spark. Nothing. Any ideas???? PLease!! Greg
    Aug 2013
    Firestone, CO
    First make sure the dist is turning, then check for voltage at the coil. It may be a pickup in the dist? Not sure what tools you have to check signals to the coil?
    1986 Ford Mustang GT-
    Not much stock stuff left
    1981 Mustang GT-
    In the middle of rebuild
    1986 LX Sedan-
    Plans to be determined...
