So I was hearing a screaming/whistling noise coming from my engine bay after I took my hood off and when I listened closer I think I narrowed it down to my ignition coil. This is an old 302. Barely any electronics. Im not sure what would cause it to do that but it doesn't sound good. Most of the time it wont even stay running for more than 4-6 seconds and when it stops running, the tach (electronic) stops working even though the engine is still rotating and the key is in the on position. I was told that the tach is hooked up to the ignition coil so I figured that that might help with narrowing down the problem. One of my buddies mentioned that it is a voltage problem but he cant remember what was the cause. So here I am lol. Thanks for any and all help.
