Page 2 of 2 FirstFirst 12
Results 26 to 46 of 46
  1. #26
    Jan 2004
    Arlington Washington
    My package with the intercooler pipe for the hot side finally showed up so here is the first very ruff mock up. I realized that the hot side was going to have to go the top inlet of the intercooler instead of the bottom inlet.
    SAM_0438 by capri_nut82, on Flickr
    SAM_0439 by capri_nut82, on Flickr
    SAM_0440 by capri_nut82, on Flickr
    SAM_0442 by capri_nut82, on Flickr
    The cold side pipe will be on the bottom allowing me to use a "S" bend pipe to off set the cold from the hot pipe and to get me closer to the throttle body.
    SAM_0445 by capri_nut82, on Flickr
    1982 Capri RS 5.0L
  2. #27
    Lookin' good mate, keep it up!!!
    Ausie, Aussie, Aussie
    Oi, Oi, Oi
    84 1C SVO "Blackie the Wonderbeater" (DECEASED!!!!)
    84 9L SVO T-TOP (under restoration)
    84 1C SVO T-TOP (Deceased)
    86 2R SVO (roller, future pro-tourer)
  3. #28
    Jan 2004
    Well my other 2 bends showed up and we flipped the one end tank. When you do this you will have to cut the inlet nipple itself off. In its place you will cut and weld the cast aluminum elbow on so that its angled up at about a 45* angle.
    This pic shows ruffly how much of the elbow you will be using. However the orientation of the elbow and end tank is WRONG in this pic.
    SAM_0524 by capri_nut82, on Flickr
    These two pics are taken from the inside of the engine bay looking towards the passenger side with the a/c condenser on your left. Here you can see the angle of the 90* elbow and the 6" peace of straight pipe I welded on the end.
    SAM_0589 by capri_nut82, on Flickr
    SAM_0590 by capri_nut82, on Flickr
    SAM_0694 by capri_nut82, on Flickr
    This is the result...... sorry about the cell phone picture.
    1982 Capri RS 5.0L
  4. #29
    Jul 2004
    Montebello, CA
    looks like your dad will figure it out!
    Past 4 eyes-
    U.S. NAVY 1980-2009
  5. #30
    Jan 2004
    Ok so I got the core completely mounted with brackets upfront, then took the core, brackets, and all the pipes to the welder for a final weld. With that all out of the way dad and I stuck the rubber mounts minus the brackets back on the condenser. The lower rubbers still had the nipples going straight down so we drilled holes in the core support for them to lock into. I managed to fab one of the two new upper brackets before we called it a night.
    SAM_0599 by capri_nut82, on Flickr
    SAM_0595 by capri_nut82, on Flickr
    SAM_0596 by capri_nut82, on Flickr
    SAM_0602 by capri_nut82, on Flickr
    SAM_0603 by capri_nut82, on Flickr
    SAM_0607 by capri_nut82, on Flickr
    SAM_0606 by capri_nut82, on Flickr
    SAM_0582 by capri_nut82, on Flickr
    SAM_0580 by capri_nut82, on Flickr
    SAM_0578 by capri_nut82, on Flickr
    SAM_0581 by capri_nut82, on Flickr
    SAM_0585 by capri_nut82, on Flickr
    SAM_0587 by capri_nut82, on Flickr
    SAM_0570 by capri_nut82, on Flickr
    SAM_0594 by capri_nut82, on Flickr
    SAM_0593 by capri_nut82, on Flickr
    SAM_0592 by capri_nut82, on Flickr
    We'll be back with more!
    SAM_0577 by capri_nut82, on Flickr
    1982 Capri RS 5.0L
  6. #31
    Jan 2004
    Dad and I got the tubes bead rolled, the three bungs welded in, and the lower radiator brackets made.
    We still need to mount the fan, fab one upper radiator bracket, wire up the fan relay, and put it all back together..... 5 days left before the show.
    1982 Capri RS 5.0L
  7. #32
    Jan 2004
    Just a quick update, I did get this built but ran into electric problems full update to come in a few days.
    1982 Capri RS 5.0L
  8. #33
  9. #34
    Jan 2006
    Western MA
    Looks real good Nelson!!!
    1986 SVO Mustang - 1C
  10. #35
    Jan 2004
    Oh I was just wondering if anyone was still interested. Sometimes its fun to watch ya'll.....
    Heck on svocop I'd be banned till my next post.
    1982 Capri RS 5.0L
  11. #36
    Jan 2004
    So here we are punching the holes I need to weld the senor bungs and bypass pipe vent in. If your building this system you can skip this step for the bungs but not the bypass.
    SAM_0647 by capri_nut82, on Flickr
    SAM_0648 by capri_nut82, on Flickr
    SAM_0651 by capri_nut82, on Flickr
    SAM_0655 by capri_nut82, on Flickr
    Remember that 6" peace of 1"od aluminum pipe you need to make a 45* cut on it so you can make it look like this.
    SAM_0649 by capri_nut82, on Flickr
    SAM_0650 by capri_nut82, on Flickr
    SAM_0652 by capri_nut82, on Flickr
    SAM_0653 by capri_nut82, on Flickr
    SAM_0654 by capri_nut82, on Flickr
    Now because when I ordered my radiator I missed the inlet and outlet nipple sizes as being wrong so those had to be cut off and the new 1 1/4" inlet and 1 1/2" outlet welded on. We also added the drain plug we got from rondavisradiators.com.
    SAM_0656 by capri_nut82, on Flickr
    SAM_0657 by capri_nut82, on Flickr
    SAM_0658 by capri_nut82, on Flickr
    From there we tapped some foam rubber to the bottom of the radiator end tanks this aloud us to make patterns and then the actual metal saddle brackets.
    SAM_0659 by capri_nut82, on Flickr
    SAM_0660 by capri_nut82, on Flickr
    SAM_0663 by capri_nut82, on Flickr
    Once this part of the brackets were made we tried to set the radiator in the car only to realize that tab I had bent down on the original radiator bracket had to be cut off. So out came the sawzall.
    SAM_0661 by capri_nut82, on Flickr
    Using the wood blocks we were able set our height for the radiator so we could shape the second part of the radiator support brackets.
    SAM_0662 by capri_nut82, on Flickr
    1982 Capri RS 5.0L
  12. #37
    Jan 2004
    Here are the lower radiator supports as we finish them up.
    SAM_0676 by capri_nut82, on Flickr
    SAM_0677 by capri_nut82, on Flickr
    SAM_0678 by capri_nut82, on Flickr
    SAM_0688 by capri_nut82, on Flickr
    SAM_0689 by capri_nut82, on Flickr
    This is the foam we used.
    SAM_0691 by capri_nut82, on Flickr
    With the brackets made up we turned to making the spal fan brackets. These are really simple to make and our held in place by slipping a small headed metric bolt into the fans pockets with bolts washers and lock nuts to keep it all together.
    SAM_0665 by capri_nut82, on Flickr
    SAM_0666 by capri_nut82, on Flickr
    SAM_0667 by capri_nut82, on Flickr
    SAM_0668 by capri_nut82, on Flickr
    SAM_0669 by capri_nut82, on Flickr
    Got the radiator and other goodies back from their final welding.
    SAM_0670 by capri_nut82, on Flickr
    SAM_0671 by capri_nut82, on Flickr
    SAM_0672 by capri_nut82, on Flickr
    SAM_0673 by capri_nut82, on Flickr
    SAM_0674 by capri_nut82, on Flickr
    SAM_0675 by capri_nut82, on Flickr
    Finished the last two fan brackets.
    SAM_0679 by capri_nut82, on Flickr
    SAM_0680 by capri_nut82, on Flickr
    1982 Capri RS 5.0L
  13. #38
    Jan 2004
    With everything more or less built it we had to bead roll all the pipe ends that didn't already have one. I think we had to do six total rolls. To do this we went up to my uncles street rod shop called Extreme Metal and Paint to use his VERY expensive Lazze Bead roller. Needless to say some of the pipes like the one attached to the 90* elbow on the intercooler was very interesting to roll because we had to spin the entire core around the pipes axis. I took pic of this mess but my phone ate them so I'm sorry guys!
    Now onto the part where I prime and paint everything!
    SAM_0681 by capri_nut82, on Flickr
    SAM_0682 by capri_nut82, on Flickr
    SAM_0683 by capri_nut82, on Flickr
    Hung these in the old chicken coupe.
    SAM_0684 by capri_nut82, on Flickr
    SAM_0685 by capri_nut82, on Flickr
    And here we go all painted and ready for final install!
    SAM_0686 by capri_nut82, on Flickr
    SAM_0687 by capri_nut82, on Flickr
    Take note of the clamp placement, the big zip tie, and how close the condenser is. The zip is to keep the upper pipe from bouncing around a lot.
    SAM_0692 by capri_nut82, on Flickr
    SAM_0693 by capri_nut82, on Flickr
    Radiator is in place with the drivers side upper bracket in its stock spot. The passenger side brackets used a pre existing hole but I got the bolt out of my spare parts bin.
    SAM_0698 by capri_nut82, on Flickr
    SAM_0697 by capri_nut82, on Flickr
    For the lower radiator hose all ya need to do is trim a bit of the hose till ya get the fit you want.
    SAM_0695 by capri_nut82, on Flickr
    SAM_0696 by capri_nut82, on Flickr
    Everything just clears the lower hose.
    SAM_0714 by capri_nut82, on Flickr
    For the upper hose I bought a new model year correct hose from Shucks and cut about 3" off of the thermostat side and about 1" off the radiator side.
    SAM_0699 by capri_nut82, on Flickr
    SAM_0700 by capri_nut82, on Flickr
    SAM_0712 by capri_nut82, on Flickr
    SAM_0713 by capri_nut82, on Flickr
    1982 Capri RS 5.0L
  14. #39
    Jan 2004
    Bead rolling the oil cooler lines.
    SAM_0701 by capri_nut82, on Flickr
    SAM_0702 by capri_nut82, on Flickr
    We took the bracket off the stock oil cooler and made it fit the new one.
    SAM_0703 by capri_nut82, on Flickr
    SAM_0704 by capri_nut82, on Flickr
    SAM_0707 by capri_nut82, on Flickr
    Making the upper support bracket for the trans cooler while using the stock bolt and hole. Plus a bit of paint.
    SAM_0708 by capri_nut82, on Flickr
    SAM_0709 by capri_nut82, on Flickr
    SAM_0710 by capri_nut82, on Flickr
    Now I didn't want the fan brackets resting on the radiator fins so I made really thin rubber gaskets from the material you put under your shower stall.
    SAM_0705 by capri_nut82, on Flickr
    Painted the upper brackets.
    SAM_0706 by capri_nut82, on Flickr
    This is where we put the fan relay switch. My spal fan was popping the 30 amp units fuses so later after calling spall I stepped up to 40 amp goods.
    SAM_0711 by capri_nut82, on Flickr
    I HATE wiring!
    IMG_20140814_050713_078 by capri_nut82, on Flickr
    IMG_20140814_050735_508 by capri_nut82, on Flickr
    Had to tuck stuff back into place or the nose would not go on.
    IMG_20140814_050722_722 by capri_nut82, on Flickr
    Uh that ain't right!
    SAM_0717 by capri_nut82, on Flickr
    SAM_0718 by capri_nut82, on Flickr
    1982 Capri RS 5.0L
  15. #40
    Jan 2004
    All finished up plus the 3G alternator needed to run the Spal fan!
    {1-23-18, I will be adding a link to new post where I detail how to do the 3G swap and the fan relay}
    SAM_0866 by capri_nut82, on Flickr
    SAM_0870 by capri_nut82, on Flickr
    SAM_0871 by capri_nut82, on Flickr
    SAM_0872 by capri_nut82, on Flickr
    SAM_0873 by capri_nut82, on Flickr
    SAM_0874 by capri_nut82, on Flickr
    SAM_0875 by capri_nut82, on Flickr
    The charcoal canister went back into its factory spot.
    SAM_0867 by capri_nut82, on Flickr
    We didn't have to but we trimmed about 1/2" off the bumper cover at the corners of the intercooler so the cover would not rub on the core fins.
    SAM_0879 by capri_nut82, on Flickr
    And the amount of clearance to the header panel.
    SAM_0881 by capri_nut82, on Flickr
    Video to come and the front page 1st post is updated with the parts list and some major notes.
    1982 Capri RS 5.0L
  16. #41
    Jan 2004
    So now that I have been driving this for a while I can report a few things. First is in my around town mpg went up 2mpg. Second sometimes when I am pulling 7-10 psi if boost in 5th gear on the freeway like ya would to pass someone, when I let off the throttle the car shudders. Its almost like the bypass valve is not able to vent the boost fast enough maybe. Makes me wish I had stepped up to a bigger one or a blow off valve. Thirdly at 15 psi I don't get the kick in the pants feeling I once did. But at 17psi I can feel it, but still can't support that much boost it feels like it either pulling timing or blowing the fire out. Gapping the plugs down to .032 helped but I think I'll try em at .028. If that doesn't fix it I will have to get my afr gauge set up to make sure im still ok.
    1982 Capri RS 5.0L
  17. #42
    On my car when I went to the Stinger FMIC from the non-intercooled 86 TC setup, I picked up a huge boost lag. Part of it was that my engine was just really tired, the intercooler really brought the leaky head's problems out into the daylight. After the rebuild, the lag dropped considerably. I'm running an RFL knock off BOV, cheap POS but whatever... It works ok, except I have to choose between setting it so tight that it doesn't open unless it really needs to (high rpm, high boost), or setting it so loose that at highway speeds it opens letting in unmetered air and causing problems when I let off the gas.
    1986 Mustang Notch, 2.3L Turbo Project
  18. #43
    FEP Senior Member E2ZZGLX's Avatar
    Jan 2012
    Broomfield Colorado
    Has anybody thought about running a shorty radiator with intercooler in a fox...Merkur guys do it all the time and think it was OEM on a cossy...Attachment 79494
    Current keepers...
    77 Cobra II
    80 Bobcat Sport
    82 GT-first new car is back home!
    85 ASC Coupe
    86 SVO
    86 Escort GT
    88 Ranger GT
  19. #44
    Jan 2004
    Quote Originally Posted by E2ZZGLX View Post
    I actually tried to make that work but no one had one in stock and I didn't see where the core would get much airflow.
    1982 Capri RS 5.0L
  20. #45
    Jan 2004
    Back in February I got the chance to tack this set up to the track and it worked really well until the last straight away where the car started to fall on its face due to the computer puling timing. The next step is to get my AFR gauge in and see what that shows, but I think in the end the head is going to need to be pulled and checked for CC as I think its been cut to many times. If its not to bad I hope to fix that with comic head gasket of the right thickness.
    me by capri_nut82, on Flickr
    1982 Capri RS 5.0L
  21. #46
    Jan 2004
    My apologies to the guys who were following my threads as I have seriously neglected them due to.... life happening.
    So since my last post a great deal has happened to the svo. One of the problems that plagued the driveability of my FMIC was the bosche bypass valve. Once I swapped it out for a GoFastBits unit the trailer hitching and compressor surge all went away. Now at the same time I also added and Electronic Boost controller from GFB to help with boost creep that I was getting with the gillis valve. I cover the install of these items here in this thread... http://vb.foureyedpride.com/showthre...d-Bypass-Valve This was also a success but what I didn't realize at the time was that the motor wasn't falling on its face due to timing or plug gap. I actually had a much bigger problem in the form of excessive piston to wall clearance. The speedpro replacement pistons called for .003" clearance, the machine shop gave .005" and by 40k miles that had grown to .007". The result of this was so much blow by that when I went to boost it would send oil into the combustion chamber threw the PCV system causing the detonation that kept me from achieving high boost levels. This of course would not be discovered until I tore the motor down after it blew the dipstick out a few times. The new motor build was added to the original motor build thread starting at post #136 in this link... http://vb.foureyedpride.com/showthre...r-Mayhem/page6
    All of that being said, one last positive change the FMIC had on driveability is that the intercooler pipe in front of the Throttle Body added plenum area and aids off idle/tip in throttle response. This really makes the car a lot nicer to drive every day!
    1982 Capri RS 5.0L
