On my 85 Mustang GT Convertible AOD with CFI, the AC works intermittently. I know it has freon (just added 2lbs) and was working. Now the compressor doesn't engage.
I initially thought it was the low pressure switch, since it was low on freon before. Before when the AC was working but low on freon, I did have power to the low pressure switch. Added freon and worked like a champ for a few days. This is why I decided to check for power here, thinking maybe the switch was bad. So, I turned the AC on Max and blower on high. I pulled the low pressure wire and checked for power with my test light and nothing. I next checked the #6 fuse for AC, fuse was good.
Not sure if the issues is the switch (controller in the car where I turn on the AC/heat) or something else. Did a few searches and there were suggestions about WOT relay. Not sure where or how to test this.
A little history in the car, it's all stock, except for dual exhaust. It sat for 10-12 years under cover before I purchased it. Most everything works (except two rear window and the passenger window switch). I know sitting can take its toll on a vehicle, especially moisture and critter. There was no sign of critters but definitely some moisture. The car is a vert and top was in need of replacement when I got it. No rust, but a mildews smell in the car.
Anyone have any suggestions?
