I went out to change the oil in my 84 LX for the first time. I used to doing small block chevys, one drain plug and that's it. Well everybody has told on the 5.0's to make sure and drop the front plug also. Problem is the front sway bar was right across the bottom edge of the drain plug and can see where it rubbed at one time or is now??? So I unbolted the lower bracket's for the front swaybar and it allowed it to drop down enough to unbolt and drain. I don't understand way a swaybar would fit like that? This car was a original V-6 and they dropped a 5.0 in it, they put different swaybars in them for the V-6 versus the 5.0? If not is there a way to correct this so I'm able to drain oil without unbolting the swaybar? Also it looks like the stock swaybar and the bottom brackets the rubber is shot in them, is there something better then putting rubber back in them? Thanks wasn't ready to start the front suspension yet just got done doing the rear suspension, just figured for now since I had the front brackets unbolted if I good make it better for now!!!
