Good news! Decided to pull the trigger on the new Fuel system. All of the old Nylon lines have been removed and am going the Stainless route.
Doing the fuel system on a Fox can be a bit confusing, even with all of the info out there. So in order to clarify a bit, I made a Flow diagram to help explain what fittings should be needed. If during the install I find that anything is screwy I'll adjust the diagram a bit and remove the one below so not to cause any confusion.
This utilizes the stock pump bracket (The pump is a Walboro 255).
Everything should be here Wed's, I'm hoping to get it all in place on Saturday night.
As an added note, it doesn't look like the Gas Gauge has been working very well in the car, going to go ahead and replace the Level Sending Unit since it's likely pretty old.
