I'm having a hard time finding a 2 wire alternator plug for my 86 mustang v8. Can I use the 87+ 3 wire alternator plug but only use the yellow and green wire and not use the white wire?
Current Cars:
1979 Mustang Ghia Coupe 5.0 3J Bright Blue
1984 GT T top 306 5 speed "Black Mamba"
1986 Saleen Black with Silver Stripes 86#009
1986 Mustang GT Medium Canyon Red 5 speed 5.0
1999 Mustang GT Convertible 35th anniversary 69K miles.
2002 Nissan Maxima 6 Speed "Daily Driver"
2009 Corvette 6 speed LS3
1998 Cobra 71k miles Canary Yellow "Nana" SOLD
Double check this as I am nowhere near an alternator or wiring to verify this.
If this is the correct plug, but with the extra wire http://www.repairconnector.com/produ...252d-1989.html then I believe you can just not connect the one wire and you should be fine.
Again, double check the actual connection to verify this as I haven't wired up an alternator in awhile.
Trey
Trey
Trey,
Its actually this one http://www.repairconnector.com/produ...Connector.html
Its flat on one side and rounded on the opposite.
What is the white wire in the middle for? Stator?
My harness currently only has the yellow and green wire.
And this is the one I found in my stash of extra parts.
Current Cars:
The Standard S-737 may be what you're looking for -
http://www.rockauto.com/catalog/moreinfo.php?pk=50380&cc=1133840
Cheers,
Jeff Cook
The one I need had 3 vertical lines on the plug with only two wires coming out (green and yellow). I ended up using the 3 wire plug but only hooked up the two wires and it seems to work fine. I drove it for about 20-30 minutes and it held up so far. I also did the quick disconnect the neg battery cable while the car is on to see if it shuts off test and it stayed on.
Current Cars:
