where to buy "heat sink paste" the white stuff used between the ignition module and the distributor. I checked at Autozone and they don't have it.
*FOXTOBERFEST* 2015 http://www.foxmustangrestoration.com/events
85 T Top coupe 5.0 2R red, E7's, rpm intake, 4180 carb, 7.4 1/8
83 CC capri 5.0 5 speed,black mesh wheels
76 cobra II 302 auto black/gold, big cam 3 inch dumps- sold to a good friend
92 coupe 5.0 5 speed -red
92 Lx hatch 5.0 5 speed -black, 66 coupe 5.0 4 spd (project)
87 Vert 5.0 AOD red stock as a rock
" Are you sure you know what you're talking about? It kinda sounds like you know what you're talking about"
If you have a Micro Center, or Frys Electronics, or possibly Radio Shack will have heat sink compound.
Dielectric grease can also be used, but it's not as thermally conductive, so I prefer to use the proper
compound.
Cheers,
Jeff Cook
I would think you could use this, providing you still have a Radio Shack
http://www.radioshack.com/product/in...ductId=2102858
thanks, I'll check RS and the electronic supply, I've used dielectric grease also but found out it's not the right stuff
