My dome and map lights are out. I checked the fuse (15 amp) and it was blown. I put a new one in and it blew as soon as I pushed it in. Tried it again and the next one blew. Any thoughts?
1986 Mustang GT w/T-Tops
This can help locate where the short is.... Pull all of the light bulbs out of the circuit, then try installing the fuse. If it doesn't blow, remove the fuse, then insert one lamp at a time, and see if it blows the fuse. When you get to one that blows the fuse, you know the area to investigate for a short.
There is definitely a short in the system. I would suspect a shorted door switch.
Dave
1983 Capri RS Turbo
1981 Black Magic 400 c6
93 F-250 351 5sp 4x4
None of the bulbs cause the problem. I've taken all of the bulbs out. If I open either door, or turn on the dome lights with the headlight switch, the fuse blows. So I'm thinking the common link is the headlight switch? Or a short behind the fuse box?
Same problem with me . I can't find out where it's coming from
Aren't those snakey maplights notorious for developing shorts?
Found this...
http://www.ascmclarencoupe.com/Proje...htRestoration/
On my way back to the garage!!
I removed the map light and started looking at the rebuild link above. I didn't want to take that thing apart or remove the heat welds. So I did an old trick that I learned years ago. I sprayed WD-40 under the switch and pushed the black button up and down to work it in. Re-installed the map light and Voila! Both dome lights and the map light works fine. Problem solved.
Glad I could help!
