yes control pack, kooks headers, UPR k-member, stifflers trans crossmember.
Float me some parts up here to ohio Larry.
Sent from my SCH-I605 using Tapatalk
u should have bought the complete project the other day ^^^^
I already had 2 mustangs in my garage.
but I had everything but fuel system and I was gonna take a huge loss....
If only I could talk the wife into matching coyote swapped 4 eyed foxes. One hatch and one notch. Guess you were going to sell before you built the engine?
the engine was out of my 2013 and did not even have 5k miles on it. I just decided to go and do good internals.
Personally I prefer Silver, but the red looks good!
Trey
Trey
anyone else doing a swap ?
Trey
Cool project. What's up with the spacers between the k-member and frame rails?
to space motor down for hood clearance for blower.
being I am probably going turbo now I can pull them out.
got a set of kooks headers for sale !
I was under the impression everyone had to space upr k member.
that would be a big NO ^^
I am planning on doing a coyote swap with 6 speed manual on my 81 Mustang coupe with T-tops. I am getting as much info as I can on these swaps.
While you are gathering info be sure to save a few dollars along the way..lol. good luck to you. I'm doing the same in an 86 hatch. Doing the body work stage right now. I'll never be able to keep up with stretch. ..I don't have his deep pockets.
Stretch aint got deep pockets !
Keep us updated on the T-top coupe.
as far as mine I am waiting on a/c parts ! being in east texas A/C is my biggest priority !
Are you sticking with the vintage air setup? I have a couple stock hvac boxes that I'm debating on just rebuilding. With all new evaporator and heater cores along with a new blower motor just so I don't have to worry. Thoughts?
Scott
Picayune,MS 39466
Torch Red 2004 Mach 1 Mustang
Silver 85 GT
Previous set up...
306, Lunati flat tappet, Eddy Performer Heads, RPM intake, Holley 650DP, Shorty Headers, Flowmasters, 3.73, T5. 12.92 @109
Current set up,,,
408w, Internally balanced Scat rotating assy, Comp Hyd roller, Brodix heads, eddy air gap RPM intake, PowerjectionIII EFI, Longtube 1-3/4 headers, Flowmasters, 3.55 Cobra 31 spline diff w/Moser axles, TKO 600 5spd, Mcleod dual disc street clutch... ET... Traction Limited 11.93 @120mph
Very clean install. What radiator setup is that?
