Results 1 to 4 of 4
    Default 1983 capri 5.0 alternator issues
    hello all new to the site just got a 1983 mercury capri 5.0 and am in the process of trying to put the car back together it set since 1994 and am to the point of trying to put the alternator back on the car when i discovered that all of the wiring for it had been cut off so i need to rewire it and was wondering if anybody had done it yet the voltage regulator is mia and i truly don't have any idea where to start
    Do you want it back to stock or are you interested in an upgrade?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Jul 2005
    Medicine Hat, Alberta,Canada
    If the wires are cut, you are better to go 3G upgrade. If you are keeping it stock, fix er up!
    i was considering the upgrade to the 3g just trying to figure out what would be the easiest way to go
