RF-E4ZE-9425-GA
RF-E5ZE-9425-GA
RF-E3ZE-9425-FD
RF-E4ZE-9425-ZA
what different between these E3-e4-e5 ? which one is more factory correct ford intake for my 85 mustang gt 4.0 4v ? I look on ebay, and most list can fit 85 mustang gt.
RF-E4ZE-9425-GA
RF-E5ZE-9425-GA
RF-E3ZE-9425-FD
RF-E4ZE-9425-ZA
Always Stay Humble. -Sinister-
Someone correct me if I'm wrong but I think E3 is for 1983, E4 is for 1984 and E5 is for 1985. The 1994 started with the F letters.
1985 Mustang GT 5speed LRB with Ford Racing M-6007-X302, Performer RPM, Holley 670 Avenger carb, BBK headers with H-pipe, B&M short throw
1986 Mustang GT (parts car)
1986 LX Coupe 4cyl, 4speed, LRB
I'm going to go with
RF-E4ZE-9425-GA
*FOXTOBERFEST* 2015 http://www.foxmustangrestoration.com/events
85 T Top coupe 5.0 2R red, E7's, rpm intake, 4180 carb, 7.4 1/8
83 CC capri 5.0 5 speed,black mesh wheels
76 cobra II 302 auto black/gold, big cam 3 inch dumps- sold to a good friend
92 coupe 5.0 5 speed -red
92 Lx hatch 5.0 5 speed -black, 66 coupe 5.0 4 spd (project)
87 Vert 5.0 AOD red stock as a rock
" Are you sure you know what you're talking about? It kinda sounds like you know what you're talking about"
To the best of my knowledge, the E3 intake was used on 83s only, 84 & 85 used the E4 intake. I have a couple of each, and the only visual differance between the 2 that I have noticed in the EGR hole is a bit different at the carb flange. (actually the EGR spacer flange would be more accurate.)
Im thinking delete the smog pump and EGR , what is the edelbrock directly replacement for RF-E4ZE-9425-GA .
I think my intake have a EGR spacer, after delete the EGR, I could just take that spacer out right ? and just put a plain square spacer on it ?
RF-E5ZE-9425-GA
I'll go with that one..
1986 CHP SSP Coupe
E1ZZ-9424-B EXC. TC, 1980/1986 1
E5ZZ-9424-A LOWER, TC ``BEFORE 4/85'', 1985 1
E5ZZ-9424-C LOWER, TC ``FROM 4/85'', 1985/1986 1
E5ZZ-9424-B UPPER, TC, 1985/1986 1
E4ZZ-9424-A 1984/1987 1
E4ZZ-9424-E ALUMINUM, F M/T, 1984/1985 1
EOVZ-9424-B ALUMINUM, F A/T, 1985
hope this helps.
HAD
HAVE
Im thinking edelbrock , but I dont know which one that will direct replacement, over RF-E4ZE-9425-GA, with all the sensor same location.... my buddy say he can port the old intake, mind already a tiny crack, it does not leak or anything, but that something I will have to replace in future, so might as well do it now. And while im at it, I remove those smog , emission stuff, my smog pump about to go out...
HAD
HAVE
1985 Mustang GT - original short block w/ bolt-ons
1995 Mustang GT - supercharged 331
2007 Mustang BDX - (Barber Driving Experience) designed for daily driving and track use
I kept my engine stock looking with Ford parts to the average eye and did away with all the smog equipment. The GT40p heads are so efficient they do not have thermactor plumbing and that is topped off with a Ford Racing intake manifold and FRPP stainless steel headers. The rest is stock and in its original place, so unless you really know what you are looking at it appears stock...until you fire it up and the Ford Racing E-303 cam starts talking!
HAD
HAVE
Yours is an example of "stock looking" with some performance enhancements. The OP seems to want everything "stock", except for the smog equipment. I found that a little curious.
My combo happens to be stock looking also, but have kept the emissions equipment in place. See my album if interested.
