Results 1 to 3 of 3
    FEP Member dk5_cobra's Avatar
    Feb 2011
    Vero Beach, Florida, United States
    Default '79 a/c information
    hey all its been a long time since I posted anything but I'm back to making progress on my build. currently I've got the dash pulled on my 1979 cobra currently and while it's out I wanted to replace certain components that are now more than 30 years old. These include the heater core and evaporator core mainly (5.0 with factory air). I had no problem sourcing a heater core but I can't find an evaporator to save my life.
    A few phone calls got me a couple of different part numbers but nobody has one for a 79. So what I'm looking to find out is what kind of interchangeability I have with my current heater/blower assembly between other years for the evaporator. I know I could change the whole system to a later year setup but I'd like to keep this as simple as possible so I can focus on other aspects of the car.
    So if anyone knows somewhere that sells new evaporators for a 79, or knows if I could use a 80-82 one, please let me know. Or maybe I'll be okay with my current one. There's no guarantee it's bad but the car has been sitting inside for almost 20 years so I figured replace it while its still easy.
    thanks in advance.
    Well, let's back this up a bit. Is there something wrong with your evaporator core? I've still got the original in
    my '65, among others. If the fittings were kept covered, it should be a simple matter of flushing and pressure
    testing the one you have. Evaporators don't really have a "use by" date.
    Cheers,
    Jeff Cook
    Feb 2011
    That's partially what I was thinking. It was all left hooked up so the fittings should be fine. Nothings been pressure tested I was just thinking about it since I have mose of the other components disassembled.
