Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
  1. #26
    I will update ownership in the database. (I do not put private owner names in the publicly-viewable 'registry'.)
    I can try to decode that build sheet but I do not have much LTD/Marquis build sheet data to start with, so decoding will not be as extensive as what I can decode on Capri/Mustang sheets.
    You asked about it, so I dug it out. I'll be interested to see what you find out.
    83 TC "Clone"
    85 Marquis LTS
  2. #27
    Line A
    Rotations Number - 0596 = trim & chassis rotations #0596
    Line - I = Marquis model line
    VIN - P89FG644172 = [partial VIN]
    Body Type - 54D = LTD/Marquis 4-door sedan
    Ext, Paint, Body - 1C = Black exterior paint color
    Int, Trim - BA = cloth Sport seating with blue inserts, low-back front buckets (B), Charcoal interior color (A)
    Int, Deviation - [blank] = no interior trim deviation
    I.B. Color - A = Charcoal instrument board (dash) color
    Type of Order - 5 = Fleet order
    Region & District - A1 = Central Ford of Canada district sales office
    Special Order - [blank] = not a special order
    Line B
    Emission Control - [blank] = no special emissions package
    Engine - M = H.O. 5.0L V8 engine
    Trans - T = automatic overdrive (AOD) transmission
    Air Cond - A = auto temperature air conditioner
    Engine, Tag Number - 5K334AA = 50-state calibration (5), Thermactor emissions with or without A/C (K), 5.0L engine (334), release level AA
    Therm, Air Pump - MO = Thermactor air pump for 5.0L engine
    Transmission, Part Number - E5ZPEA = automatic transmission (P) originally engineered for 1985 (E5) Mustang (Z), release level EA
    Seats, Power - S = power seats
    Seats, Type - 2 = low-back bucket seating
    Carbon Canister - P = carbon (charcoal) canister for 5.0L engine with E.F.I.
    Modules Ign - [blank] = no Duraspark ignition module
    Modules, EEC/MCU - SM = unknown EEC module code
    Line C
    Imm Block Heater - [blank] = no engine block immersion heater
    Power Steering, Oil Cooler - [blank] = no power steering cooler
    Power Steering, Pump - G = power steering pump for late (after September 1984) 5.0L engine with E.F.I.
    Alternator, Code - 6Z = alternator for 5.0L engine with E.F.I.
    Line D
    Electrical, Wipers - W = interval windshield wipers
    Electrical, Defroster - E = electric rear window defroster
    Electrical, Clock/Trip - Y = clock or tripminder (?)
    Electrical, Audio, Radio - 2 = AM/FM stereo radio
    Electrical, Audio, Speakers - X = four speakers with premium sound system
    Electrical, Audio, Antenna - A = automatic antenna
    Electrical, Light, Entry Dimmer - E = illuminated entry system
    Electrical, Lights, Light Group - V = visibility/light group
    Power Aids, Decklid Release - D = remote decklid release
    Power Aids, Locks - L = power door locks
    Power Aids, Doors - B = power windows
    Glass, Tint - T = tinted glass
    Road Abrasion - R = road abrasion protection
    Carpet/Mats - [blank] = no floor mats
    Mirror, Outside - F = power remote control mirrors
    Line E
    Driveline, Speed-O, Metric - M = metric (km/h) speedometer
    Driveline, Speed-O, Gear 2 - T = Tan (C7VY-17271-A) speedometer driven gear
    Driveline, Rear Axle, Tag Number - 939C = 3.27:1 axle ratio, Traction-Lok (limited slip) differential
    Suspension, Springs, Front, Left - VOV = F front left spring code
    Suspension, Springs, Front, Right - VOV = F front right spring code
    Suspension, Springs, Rear, Left - CAG = X rear left spring code
    Suspension, Springs, Rear, Right - CAG = X rear right spring code
    Line F
    Tires, Goodyear - 4 = Goodyear tires
    Tires, Size - 2057014 = P205/70HR14 tires
    Tires, Quantity - 4 = four full size tires
    Speed Control - S = fingertip speed control (cruise control)
    Frt License Plate Bracket - X = front license plate bracket
    Line G
    Accent Stripe, Type/Color - BE = Canyon Red paint stripes
    Export/French - C = Canadian labels
    Fuel, Sender - 7 = sending unit for CFI 5.0L
    VIN - 1MEBM4 = [partial VIN]
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
  3. #28
    Line A
    Awesome, thanks!
    83 TC "Clone"
    85 Marquis LTS
  4. #29
    When I get a chance, I'll get you the VIN off of the door tag of the LX parts car I got the doors, etc from.
    83 TC "Clone"
    85 Marquis LTS
  5. #30
    Door tag from that LX parts car that was in PA.
    (It had no title and is going to be scrapped. I pulled a bunch of stuff from it)
    83 TC "Clone"
    85 Marquis LTS
  6. #31
    VIN
    1FA = Ford vehicle manufactured in USA by Ford Motor Company
    B = active belts, no airbags
    P = passenger car
    39 = LTD 4-door sedan
    4 = VIN check digit
    F = 1985 model year
    G = Chicago Assembly
    150744 = 50,744th 1985 Ford scheduled for production at Chicago Assembly
    Door Tag
    Date - 11/84 = November 1984 build
    GVWR - 4370 lb/1982 kg = gross vehicle weight rating
    Front GAWR - 2217 lb/1005 kg = front gross axle weight rating
    Rear GAWR - 2323 lb/1053 kg = rear gross axle weight rating
    F0004 = 0004 lbs front accessory reserve load
    R0044 = 0044 lbs rear accessory reserve load
    Exterior Paint Colors - 1C = Black
    DSO - 16 = Philadelphia district sales office
    Body - 54D = LTD/Marquis 4-door sedan
    VR - [blank] = no vinyl or cloth roof
    Mldg - B2P = Charcoal bodyside molding with Red-Orange stripes
    Int Trim - BA = cloth Sport seating with blue inserts, low-back front buckets (B), Charcoal interior color (A)
    AC - [blank] = no paint stripes (?)
    R - 4 = AM/FM stereo radio
    Ax - E = 3.27:1 axle ratio, Traction-Lok (limited slip) differential
    Tr - T = automatic overrdive transmission (AOD)
    FF = front springs
    XX = rear springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
