Got my "new" trans today!!!!
<Dayne>
1985 Monte Carlo SS 5.7
1993 Civic Coupe JDM B16A1
1982 Mustang GT 5.0
1980 Mustang Notchback 5.0
1993 Civic SI D16Z6
1991 Camaro RS 3.1
1978 Honda Accord CVCC 1.6
1983 Camaro Berlinetta 2.8
1981 Mustang Notchback ...Engineless...again
Adjust ds door striker bolt inward.
Door now closes/latches the rest of the way, flush.
No more door 'clunking' (was mistaken for window rattle).
Also got a warning light, on the graphic display, for running lights and brake light.
-Right turn signal no flash, stayed on.
-All lights were lit.
Turned on emgy flashers
-RR tail light not flashing correctly. Bulbs were flashing out of sync.
Smacked tail light assy with hand.
Had to repeat procedure later that evening.
All lights now working fine.
1986 Ford Mustang GT-
Not much stock stuff left
347 NA power, CNC ported heads, Extrude honed Trick Flow Intake, Custom Cam
Suspension, custom k- member, TQ arm/pan hard rod... Much more
Restored and ready to race, made to go fast while cornering
1981 Mustang GT-
Old SCCA A-Sedan National Champ car
In the middle of rebuild
1986 LX Sedan-
Plans to be determined...
"Every day I learn how much I don't know"
I got the fuse block from a local electronics shop called or VAC electronics . Though I'm sure you can find it online
Sent from my XT897 using Tapatalk
1985 Ford LTD LX. 4 eyes, 4 doors-cobra powered
2006 Ford F-150 Ashley/Smith special edition--the "daily driver"
1986 ford mustang SVO--a man can always dream right?
built an exhaust, all 3" summit bends/xpipe/flanges, dynomax ultra flows.
working on a pedal swap to finish up the Auto to T5 swap
1980 Capri
5.0 EFI Mass Air, Rebuilt T5, Centerforce Dual Friction, B&M Ripper Shifter, Aluminum Driveshaft, 5 Lug 8.8, Cobra Brakes, Maximum Motorsports HD Lower Control Arms 94GT Spindles, 94 Front Control Arms, B Springs, Tokico Shocks & Struts, MM Camber Plates
Had to have a coolant line and fitting made for the C-3 auto ........Do'h.........
Scotty
Past Pony's.....
Pulled the cover off and put the battery on charge. I sold some bits and finally saved enough to order my tubular k-member kit today. Team-z metal matrix with their autocross a-arms and 12-175 coil over spring kit for the front. Said that he had to make the a-arms which may take a week by the time they come back from paint/powdercoat. Not in a big hurry. Maybe I can start pulling the car to bits in preparation?
trans is shot no first or 4th pissed but w/e doing a v8 swap this summer
<Dayne>
1982 Mustang GT 5.0
1993 Civic SI D16Z6
1991 Camaro RS 3.1
Pulled the passenger door apart, glass out etc - cleaned it all, replaced the guide bushings, put new door panel felt/chrome swipey pieces on and put it all back together.
The drivers side gets the same treatment next weekend.
Since they are just holding down the garage floor over winter, I went and checked the tire pressures to make sure they are not getting too low and moved them just a little in an attempt to stop flat spotting the tires. Then I went back inside. It's cold out there.
84 Tan 5.0 GT hatchback
84 Tan 5.0 GT convertible
84 GT350 2.3T convertible
Well I didn't do it today because it's snowing like crazy now, but yesterday, I replaced the 2 low beam headlights with Sylvania halogens and took a 20 minute cruise on the highway. It may be the last time for awhile before I can drive her again.
"Have you ever noticed that anybody driving slower than you is an idiot, and anyone driving faster than you is a maniac."
George Carlin, Rest in peace
Rick
84 GT Convertible
68 Cougar XR7
14 Ford Explorer Limited
Starting a new thread......in place of last years
Picked up a used Edelbrock Performer 289 intake for mine from Cottonbear a few hours ago. I'm hoping it will wake up a non-roller motor as well as the same intake did on my 85. Just need to give it a once-over in my friends blast cabinet and a coat of paint.
86 Notch under construction
2011 4Runner Trail edition
2014 Suzuki V-Strom 650
Mine works great.
Bussmann 8 position.
Hot is wired thru firewall to a 30a Maxifuse, then to starter relay battery post.
Plenty of breathing room to add ATC fused stuff.
Chose to power up only in key-on position via a regular 12v 30a multipurpose square black relay.
All new ground wires are connected to a barrier strip, which I grounded to the chassis.
NAPA, Summit, Amazon, others, sell them. 6 pole is about 15.00, 8 position is about 20.00.
We are in the middle of a heat wave. This morning it was still cold so I ran the jet heater in the garage and got it nice and toasty. The Marchal covers I have are not in that good of shape. I used epoxy to strengthen one of the tabs that was about to come off. Once that was done I cleaned and painted them. I was going to be different and paint them the canyon red that is on the stripe of my GT350 but I chickened out and went white.
My son and I jumped in it since it got up to a balmy 55 degrees and put on about 40 miles of back road driving. Stopped at the park to take some photos.
I drove mine out of the shop and parked it outside all day while I pulled the engine out of a Honda parts car to put in my sons Honda
Robert
86 GT vert
85 GT
pushed the car to the side of the garage...soon as the snow melts were yanking the 2.3...
this is where my notches go when they die apparently lol
<Dayne>
1982 Mustang GT 5.0
1993 Civic SI D16Z6
1991 Camaro RS 3.1
Been parked 2 weeks. Too cold and snowy to drive it.
Took a minute. Started, idled, charged good.
Moved it to clear snow off drive.
Dang snow is covering it again.
Replay after replay. Every weekend- Snow, bitter cold, snow, bitter cold.
Too perfect of timing and pattern to be natural weather?
Spent the day flat on my back cleaning under the car. Started another catback swap - putting regular Dynomax's on it this time instead of the Dynomax VTs...
1986 Saleen #145
now 50k miles - still 98% original.
I'm all for helping the helpless, but I don't give a rat's ass about the clueless anymore.
Previous: 79 Cobra, 82 GT, 83 GT, 85 Twister, 85.5 SVO, 86 GT, 87 GT, 91 Saleen, etc....
Cleaned the mating surfaces and degreased the new-to-me intake yesterday. I actually don't think it needs to go in the blast cabinet. A coat of paint or two and it should be good to go. Sat in the car for a little while too. Spring will be here before we know it. Everything I need to do to the Capri by spring will take maybe a day. My BMW on the other hand is really torn apart.
