Well I did manage to sneak in a small amount of progress. All I really managed to do was start to get the front suspension bolted together, but as my luck goes...there's always something. But on a related note, since this car is essentially you baby daddy, the fox mustang purists can appreciate this update too.
Last week I rebuilt the LCA's and put new Energy suspension poly bushings, and 95 Mustang balljoints. Today I beat those suckers in place. ( And I do mean that in a literal sense) Then I squared up the K member using MM's method. Didn't matter,...even though the measurements showed the K member to be off significantly (1/4") I wasn't able to get it to move. I'll tell you one thing though, It ain't coming back out, and I'm not grinding on it.
As w/ several things on this build, I've been sitting on the front suspension, and brakes the longest. I bought all of that stuff at the end of last summer along w/ the wheels and tires, which was the very first UPS shipment to arrive at my door. The struts are just stock replacement KYB Gas-A-Justs, but they are for a fox body.Bolting them to a SN 95 spindle requires that a set of spacers be made, as the SN 95 spindle is narrower than the older fox strut. Additionally in my case, the bolt holes didn't line up either, and I was forced to grind the strut, and the spacers accordingly to allow them to fit.
The old fox strut was about 1/4" wider than the SN 95 spindle. Each spacer was about .120 thick.
Timken Hubs, UPR coil over kit, UPR bumpsteer kit, UPR CC plates.
Blurry assed pic.
I've assembled it w/o the spring because I need to establish a ride height so I can ck, and adust the bumpsteer out of the car. For now, everything is just loosely bolted together. I'll have to go to home depot and buy a piece of MDF so I can make the bumpsteer gauge to get the bumpsteer dialed in.
The tape measure is still laying at a diagonal after squaring up the K member, based on the plumb bobbed marks I made to the floor.
This pic actually gives you a good idea of how the satin black paint finished. You can just see my fingerprints right in front of the strut tower where I hauled my ass off the floor after bolting that side together.
Another stinkin' blurry pic. Sorry, stupid camera phone.
Your standard everyday Rock Auto Mustang performance ratio PS rack. No manual rack for this car.
That's all that got done.
