Results 1 to 4 of 4
    Default Picked up NON - HO upper intake what is it for ??
    Well to make it short I brought a used stock intake and throttle body off of what I was lead to believe a 1993 Mustang . When I got home I took a better look at it no HO stamp under the 5.0 plate and turned the wrong way for a H O , plumbing wrong and the Casting number are all wrong .Please help me I.D> this thing .On the under side of it are the casting numbers . RF_ FOVE 9425_A4B. Did not want the intake only the throttle body on it ,but now I am unsure of the size throttle or if it will even work for me . I was in a hurry and didn`t look until I got home . Live and Learn the hard way ,I always say
    I believe I found it
    F = 199?
    0 = ? = 0
    V = Lincoln
    E= Engine
    So it is for a 1990 Lincoln
    Probably from a Grand Marquis or crown vic.
    Jess
    Previously owned;
    Yes that`s what I was thinking .I know they are turned the other way . I got it off of Craigslist .I was in a big a$$ hurry to get home and beat rush hour and so I lost that one, only spend 25.00 .I can live with that .I do have the guys number so he will be getting a call from me
    He might really think that they're the same. It's an easy assumption.
