I feel like these are two separate issue's..
Does anyone have a fuse panel diagram for a 86 Svo so we can figure out which relay controls the fan?? We tested the fan and we know that thing works fine.
Also his coolant temp gauge doesnt work either..have to crawl under and make sure that wire going to the sensor near the knock sensor is still good.
Now just to reiterate the ECT on the upper intake tells the ECU to turn the fan on and the gauge is on a separate wire so those two have nothing to do with each other wiring wise?
