Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 301 to 325 of 336
Thread: My Daddywagon
  1. #301
    That's cool. Why did you start with such large spacers last time? Maximum Motorsports makes some really nice ones, FYI.
  2. #302
    I think I got caught up in the brand name and I knew I would be getting the brembos... eventually.
  3. #303
    I am experiencing difficulties with the tremec tr-3550. Specifically shifting in to second gear. Whether it’s on the upshift or downshift the trans won’t go in to second. I have to try over and over before the lever goes into gear. I am going to save for a t56.
  4. #304
    Turns out I have to use the old 1 inch spacers. The Brembos combined with these wheels require greater than 3/4 inch spacers.
  5. #305
    Jan 2005
    Cordova, TN
    Let me know when if you're going to sell that 3550. I'm looking for one or a TKO. I might even have found a great deal a top loader...but kinda want OD.
  6. #306
    Sure! Truth be told I am a hoarder of sorts. I have trouble selling. I am always thinking someday I am gonna need that... Also there is the obstacle of acquiring a T56 Magnum in my desired ratios to fit a windsor bellhousing, that I cannot afford. But as soon as all the stars in the cosmos align I will let you know. I’m gonna go buy my lottery ticket!
  7. #307
    For what you pay for a new T56, they'd better put whatever ratios you want in there!
  8. #308
    Agreed!
  9. #309
    https://youtu.be/1ws51iPu5_0
    Everything is rattlin’. It needs a lot of work!
  10. #310
    OK... In my endeavor to use an aero fox dash I am using original aero fox chassis wiring. I am attempting to pull all of the chassis wiring now. The chassis wiring is coming out of a 4 cylinder car. I believe this is gonna be a problem with the alternator wiring. That; I believe can be easily remedied. I happen to have matching year engine harness laying around. The goal is to be as stock looking as possible. It is definitely going to be a challenge. The car actually runs great. It starts right up and it idles fine. I just need the full effect... a good parking brake, a fuel gauge that works, and a nice ride. It handles great but all the rattles make it a little harsh. I also neglected to install spring insulators at all four corners. I am gonna try factory Cobra front springs and see what they do. While I'm at it I will put poly insulators on all four springs. I know it has a great stance to it and the suspension never bottoms out but I think an inch higher with a slightly cushier ride would make it perfect.
  11. #311
    Sounds awesome. Let me know what I can do to help. What are you going to do for a parking brake?
  12. #312
    Jan 2005
    Cordova, TN
    Ever do anything with the 3550?
  13. #313
    I am going to use stock fox mustang park brake lever mated to the Cobra IRS brake calipers. That is the current plan.
  14. #314
    The tremec 3550 is still in there. It’s gonna take a considerable amount of work hours before I can afford a T56... but that is the only replacement I am really interested in.
  15. #315
  16. #316
    What is it with videos on this forum? I don’t get it.
  17. #317
    Quote Originally Posted by nelzfoxes View Post
    Cool.
  18. #318
    Jan 2005
    Cordova, TN
    Videos of donuts are cool on any site! If I switch to a turbo 2.3, which is my current plan, I am probably ultimately going with a T-56 to get a more gear and more OD.
  19. #319
    https://www.youtube.com/watch?v=-LwNx60ux5o
    Re quote this, and it'll show you the way to apply the link to your Youtube. It has to be Youtube, not youtu.be.
  20. #320
    Detroit police did not like these donuts.
    https://www.youtube.com/watch?v=6lEIncsax98
  21. #321
    I am wrenching on it again. Polyurethane control arm bushings and possibly modifications to accept a fox body mustang fuel tank assembly.
  22. #322
    Awesome
    glad to see you are back at it
  23. #323
    May 2003
    Roseburg Oregon
    Is that whine your power steering ?
  24. #324
    Awesome
    Thanks! It may never end.
    Yes it is. It has a leak.
  25. #325
    Cobra R wheels and 275 width tires out back and 255 width tires up front.
