Results 1 to 25 of 32
    Feb 2012
    Florence, AL
    Default SVO side molding?
    I remember reading somewhere that you can get universal molding and use it in place of the SVO thin molding. I want to run this style on my 86 as I have not seen it on any other cars that did not come this way. Does anyone know of a source for this universal molding?
    1986 Notchback, Recently repainted Light Regatta Blue(3J) and getting put back the way it should be. It had a 3.8 and a C5. Now it has a 5.0 and a T5.
    FEP Member BrianM's Avatar
    Oct 2011
    Mandeville, LA
    Here are two sources for the aftermarket stuff I bookmarked a while back. Its not an exact replacement but about as close as you can get and cheap at less than $30 for enough to do the whole car. Paint charcoal to match 85-86. Nobody but an SVO enthusiast would be any wiser.
    http://www.repaintsupply.com/pd_cow_...pean_style.cfm
    http://secure.terrys.net/viewProduct...ctID=PT.33-322
    1970 U14 Bronco
    1983 911 SC
    Sold - 1986 SVO 1D #9823
    Feb 2012
    Florence, AL
    Now I also have them bookmarked. Thank you very much. I think my LX will look good with this molding in charcoal. I am also thinking about modifying a set of side spats as well.
    Jan 2013
    Rocky Point, NC
    You will need the rocker moldings from an svo to pull off the spats
    '86 SVO *Jenni* 2R Sunroof, Leather (Restoration in Progress)
    '06 GT G2 Vert auto 13.0 @ 105
    Feb 2012
    Florence, AL
    I would modify them to taper into the rocker. I think it would look pretty good.
    Quote Originally Posted by Domino View Post
    I am sure this could be done, but be aware that one of the mounting screws and the bracket lies under the rocker panel in a standard install. So you will need to address how to remove that and yet still attach the leading edge of the spat to the body. Not a super difficult task mind you, but worth putting some thought into as it's an area that can easily be an issue for long term durability IMHO.
    Good Luck!
    Trey
    Feb 2012
    Florence, AL
    I did not know that. I was under the impression that they were stuck on with two sided tape. I really do not want to drill a hole in my car. Thanks for the heads up.
    Yes, there are 2 holes that need to be drilled in the lower rocker area along the leading edge of the spats that the bracket inside the spat uses to hold the spat on. Then there is one screw under the rocker panel molding along with the 3 screws that are in the wheel well.
    Check out Mike's FS post that shows what the spats look like off the car. That will help you understand what would be required to mount them. http://vb.foureyedpride.com/showthre...s-and-brackets
    There is an aftermarket fiberglass version of the spats that might work for you, although I am not sure how they attach. They may still use studs for attachment.
    Good Luck!
    Trey
    Jun 2003
    Decatur Alabama
    The aftermarket ones do not have the bolts that go through the body just screws on the wheel well side and the bottom into the floor pan. They are sold by Paul Becker at svpu. $200 a set was the last price I know of.
    Kendal
    Jan 2006
    Western MA
    Here's what the spat mounting points look like:
    JT
    1986 SVO Mustang - 1C
    Feb 2012
    Florence, AL
    I am going to rethink the spats idea for now. Does anyone have close-up pics of the side molding? How long is each piece? Which pieces are beveled? I am going to order my molding pretty soon and I want to be prepared. I already have the trim paint sitting here waiting.
    autozone sells one with carbon fiber patern.. looks great and it has the same width
    Feb 2012
    Florence, AL
    I actually ordered the one from the link above. It should be here next week. I just need to figure out the lengths and the correct tapers. I am hoping someone with a real SVO can take some pics and get some measurements.
    Jan 2006
    Western MA
    I can get you some pics, but later this week. Been flat out with "stuff"....
    JT
    Feb 2012
    Florence, AL
    I would really appreciate that. I figure an 86 LX with SVO trim will be different.
    Oct 2011
    Mandeville, LA
    Molding lengths
    Front 9 1/4"
    Door 53"
    Rear 10 1/4"
    The angle at the front of the door is 1/2" long.
    1970 U14 Bronco
    1983 911 SC
    Feb 2012
    Florence, AL
    Thanks a lot. Is the one at the front of the door the only one that is angled? I am still trying to decide what will be the best thing to use to cut the molding.
    Depending on the molding you are trying to use, there are a couple of ways to cut the angle. You can use a really sharp utility blade and take care to cut straight and not cut yourself. You can make a wood jig that holds the molding and then the blade goes through a slot just like a miter box for a regular wood saw.
    You can also use a miter box with a really fine saw blade, although the cleanliness of the cut make require additional sanding or smoothing.
    You can also use a compound miter saw and a fine plywood type blade to make the cut. Make your cut at a smooth cut rate, just fast enough not to heat up the plastic and cause melting or burning, but not so fast as to leave poor cut.
    Good Luck!
    Trey
    Feb 2012
    Florence, AL
    The not cutting myself will be the hardest part. My left hand is still bandaged from an accident Thursday while trimming a hedge. I figure I will cut it to length, sit it on the car with some masking tape to ensure it does not rub anywhere, remove it to paint and install. In my head it seems simple, but I will mess it up somehow.
    FEP Super Member escogt's Avatar
    Jan 2006
    Long Island, N.Y.
    I too did that with my old '81.
    Feb 2012
    Florence, AL
    What did you use on yours? Do you have any close up pics of the trim? Mine should be here next week some time and I am ready to put it on. I really wish someone made SVO quarter trim for a coupe.
    Jan 2006
    Long Island, N.Y.
    I used OEM SVO moldings that I bought from a member here. Cleaned them up & put on some fresh 3M two sided molding tape.
    I'll see if I have some close up pics.
    Feb 2012
    Florence, AL
    I would appreciate any and all pics.
    Jan 2006
    Long Island, N.Y.
    Hope these are helpful to you.
    Feb 2012
    Florence, AL
    I see now. There is a slight bevel on the very ends, but no bevel on the front of the quarter and the rear of the door. I have saved your pics so i can enlarge them for a better view. Thanks again. My factory moldings are just too far gone to fix and I do not have the money to source good ones.
