Results 1 to 10 of 10
Thread: Bell housings
    Default Bell housings
    Greetings all,
    My 82GT has the newer T-5 transmission and the 8.8 inch rear with I believe 3.08 gears. I'd like to eventually convert it back to the SROD 4-speed and the 7.5 for originality. Guess I'm a purist. There is a parts car nearby with the original drive train from the bell housing back to the rear wheels available. Owner wouldn't mind a swap with me. Might be a delay for that. Is the bell housing on the 82 with a 4-speed the same as five speed cars? Seems like it should be but better to ask first. Thanks.
    Dec 2011
    stanton,alabama
    no there different 79-84 srod 4spd or tremec 3550 is the same and 835spd-93 is the same
    they r different..but its just the bolt holes...however the later t5 bells have the bosses still and look like they may b able to b drilled for the srod..and tremec pattern
    Sent from my SPH-L710 using Tapatalk 4
    Jeremy
    dirty one is the t5 bell..other is an srod bell
    Jeremy
    Dec 2011
    stanton,alabama
    I believe the center big hole is different also
    hmmm..I'll measure them next week. good point
    Jeremy
    FEP Super Member FM2NOTCH's Avatar
    Aug 2011
    Foothills of Piedmont NC
    I wouldn't do it, I don't see anything to be gained by installing the factory low po parts.
    FEP Power Member horsepowerjunkie's Avatar
    Jul 2009
    Juist outside Minot, ND
    ^ I agree. The T5 is light years ahead of the old SROD, in many ways. Same with the 8.8, who is gona know the difference, except you. I'd live with it.
    11 GT Black, A6,Steeda CAI, SCT X4, Circle D 4C
    89LX Blk Hatch,363 Dart,C4,T76BB,FAST EFI
    86 Black GT, 331 Dart, S-trim aftercooled, 4R70W
    82 Carpi RS, 306, T5, 8.8 4.10's.
    72 Demon 340 4-speed(one of 1667)
    73 Dart Sport 340, 410ci, Indy 230cnc+, bracket brawler
    01 Ram Quad Cab, 5.9L car hauler
    02 Grizzley 660
    03 Honda VTX 1800
    Jul 2010
    Houston (Clear Lake), Texas
    If this 82 GT is going to sit in a museum somewhere and not get driven, then by all means swap it back. The 7.5" rear end is one thing I could live with...till it breaks! The SROD would have to go...the 2nd to 3rd gear transition just makes the car horrible to drive.
    HAD
    HAVE
    Aug 2005
    Plymouth, Ma.
    The locating holes for the front bearing retainer are different sizes from the SROD to the T-5 bellhousings. The T-5 bellhousings have a bigger centering hole.
    85 G.T. All motor
    337 c.i.d 11.44-120 mph
    1984 G.T. (Daughters car)
