Up for sale is my Tangerine Capri. Most of you know the car, but here is what you get. Not for the purist by any means, but a reliable street strip car.
1984 block, .030 over. 347 cubes.
Eagle 3.4" stroker crank, ARP main studs.
Forged Eagle rods, Forged SRP pistons.
Edelbrock victor jr Cyl heads. 1.60/2.05 valves.
Lunati LSx spring kit, matched to custom cam.
Lunati solid flat tappet custom camshaft, by Flowtech Induction.
Crane gold race extruded aluminum rocker arms, Trickflow chromoly pushrods.
ARP head bolts.
Vic Jr. intake manifold. Holley 750HP carb,
Valvetrain has less than 700 miles on it, just assembled this past spring.
Chassis Dynod 341 horse and 347 torque at wheels, dyno sheet included.
Tremec TKO600 trans, Centerforce clutch, hurst shifter, Ford racing aluminum driveshaft converted to 31 spline with new front yoke.
8.8 rear with 33 spline Strange axles, C-clip elims, and a spool. Welded axle tubes, Trickflow rear diff Girdle. Motorsport 4.10 gears.
Fuel system all new. Sumped tank, Aeromotive pump, -8 and -6an lines, Aeromotive fuel filter, Holley regulator.
MSD 6al box with 3 step rev control, Billet dist, 9mm wires, Blaster coil.
BBK long tube headers, off road H-pipe, Stainless steel cat back exhaust by Magnaflow, 3 inch tips.
12 way Adjustable Strange front shocks. 3-way rears. Morroso rear trick springs, stock fronts. No front swaybar, BBK rear control arms.
Subframe connectors. Front brakes converted to 11" disks with 91 GT parts, New Moog ball joints. Manual steerign rack conversion.
125 shot of nitrous, through a Performed RPM plate kit.
New Mickey Thompson 275/60/15 drag radials, less than 300 miles on them.
Aluminum radiador, with electric fan. Converted to serp belt.
Exterior is stock appearing. Factory 79 Tangerine paint used, however was originally red.
Interior mods are basic, with Hurst shifter, Autometer gauges (have 2 more new in box to install) and a set of 91 LX sport front seats, recovered in black vinyl.
Im sure I have left alot out. I have well over 25k in this car, and I will miss it dearly. However, after 7 years of ownership, I must part ways.
Asking $8k. Located in Taunton, Ma 02780 Thanks guys.
