Is this posted on the coral? Seems to be a lot of good engine building info over there.
I haven't hit the corral with it but I have talked to Woody over there via PM's.
Pete Slaney
1979 Mustang Cobra
347/T-5/4.30's
420 rwhp/380 rwt (New Motor)
11.49 @ 121.86
306/T-5/4.30's (Old Motor)
307 rwhp/278 rwt
12.38 @ 111.38
Pete i hope you figure this all out really sorry to here you are still having issues
Thanks Chet! We'll get it. It just means more time and probably more money. It is what it is.
Pete Slaney
1979 Mustang Cobra
347/T-5/4.30's
11.49 @ 121.86
307 rwhp/278 rwt
12.38 @ 111.38
We've hurt thrust bearings with the yoke on the drive shaft. Didn't catch the splines where twisting so when you put it back in the trans I doesn't go in as far. So check the end play on the drive shaft.
I've never thought about that. We'll check that as well. In the meantime, my brother came on over and checked it when it was cold and it came in at the same .010 clearance. Thus the number did not change between hot and cold. Good sign? When my brother checked it while it was hot, I had about 110 miles on it. I then drove it 30 more miles while cruising around and then driving it home, where it's sat since. So, in the past 30 miles that measurement has stayed at .010. Good sign?
I haven't been able to drive the car for the past couple of weeks because of the weather and now the salt is all over the place. After we get a good rain storm where it doesn't freeze, I'll be driving it again. My brain has calmed down somewhat and I'll drive the car in small increments and keep measuring that crank end play. If it doesn't keep growing, I'll keep driving it. If it continues to open up and grow larger, I'll then know that I've got a serious problem on my hands again. At this point, I think I'm numb to the pain - if you know what I mean.
Pete Slaney
1979 Mustang Cobra
347/T-5/4.30's
11.49 @ 121.86
307 rwhp/278 rwt
12.38 @ 111.38
Good luck Pete.
Dave
1983 Capri RS Turbo
1981 Black Magic 400 c6
93 F-250 351 5sp 4x4
Thanks Dave! I really appreciate it.
Pete Slaney
1979 Mustang Cobra
347/T-5/4.30's
11.49 @ 121.86
307 rwhp/278 rwt
12.38 @ 111.38
I think you'll be okay. When you check the drive shaft have the wheels on blocks and allow for sup travel.
For what its worth, the 331 currently in my 85 Mustang had a similar issue with excessive crankshaft thrust clearance after a while, with an Eagle crank. At the time, it was in my buddys 64 Comet, and since it is an open header bracket racer, no funny noises were heard, but one day at the track, it was noticed that the crank had too much play while we were adjusting the clutch. He pulled it out, and the backside of the thrust bearings were all gouged up, and the mating surface of the crank was not as smooth as a factory Ford crank. There was .065" of thrust play. He tossed the Eagle crank, and bought a new Scat 3.25" stroke crank, ran the engine for 2 more seasons, and then I bought it when he decided to build a big bore 347 (4.125 bore, 3.25 stroke). I have ran the old engine for the past 2 years in my Mustang, and it still runs great, and has had no further problems with thrust clearance. My car is also a stick (Jerico 4 speed/McLeod Soft Lok clutch), and I always start my engine with the trans in neutral and clutch pedal released (no clutch switch.) I ran my Mustang in NHRA Stock Eliminator for 10 years, both in National and divisional events, and I have never had any Tech guy say that I needed to install a clutch pedal switch. And believe me, at a NHRA National event, you are getting teched by the same guys who tech the big name Pros.
Wow. What a great thread. Learned a lot from this. I hope you are able to sort everything out.
Current Ride:
2007 silver Ridgeline RTL
Past Rides:
1985 black 2.3 auto Capri
1989 black GT
2000 laser red 3.8 5-speed Mustang
Future Ride:
85/86 GT or Fox Notch or Any Cobra
Thanks! I'm keeping my fingers crossed. With the crappy weather and salt still all over the roads, I haven't been able to drive the car since then, which has been about a month. I'm chompin' for a ride!
Pete Slaney
1979 Mustang Cobra
347/T-5/4.30's
11.49 @ 121.86
307 rwhp/278 rwt
12.38 @ 111.38
O.K. guys, I've got some good news. We've finally got the car/motor to where we want it as I've been having issues with it starting while hot and also the carburetor idle kept going out of whack and idling at a minimum of 1,500 rpms. I cured the starter problem by installing a Ford Motorsport mini-starter (standard starter for '92 & '93 Mustangs) and my brother figured out the carburetor. With the carburetor, the rod that connects the linkages from both the primary side of the carburetor and the secondary side of the carburetor was bent incorrectly from the factory and it was forcing the secondary butterflies to remain slightly open, causing a lean condition at idle which we could only fix by backing the idle control screws outwards about 4 or 5 turns to compensate. This would wreck the idle and only allow it to idle at 1,500 rpms (anything lower and it would stall out). Now that those two issues have been fixed I've been driving it like crazy to get some miles on it.
I'm now up to 475 miles since the engine installation and it's been running real good with great oil pressure, plenty of power, and awesome drive-ability. In fact, it's been running so good that I thought we'd take it to the dyno today to see what it would make for power. All along I've been wanting to get it to the dyno but with all the issues we've been having that was something that just could not have happened - until today. We drove down to Mike Dez Racing in Seekonk, Massachusetts (you may have read about him in Muscle Mustangs & Fast Fords Magazine as he's been in there numerous times) and strapped it to the rollers. My twin brother's 331 stroker motor dyno'd at 387 rwhp/362 rwt so I was only expecting about the same results even though mine is a 347. What we got shocked me as it put down 408 rwhp/371 rwt on the first pull. We noticed that the air/fuel ratio on the secondary side of the carburetor was running quite lean so we pulled it off, took off the fuel bowl and changed the jets from 77's to 79's and bolted it back on. The second pull increased horsepower to 418rwhp/379 rwt. At this point we checked the timing. It was at 10 degrees and all in by 30 so we changed it to 14 and 34 then made another pull. It pinged on that run and horsepower/torque dropped as we had to abort that run. For the final pull, we backed the timing down to 12 degrees and total timing to 32 degrees. This seemed to be the sweet spot as there was no pinging, detonation, or knocking and on this final run the horsepower increased to 419rwhp/382rwt. With no changes left to make we packed up our tools and called it a day.
As for my thrust bearing? I've lived in fear of that since July and I will no longer be held hostage by it. My brother and I still have not re-checked it since it was at .10 because we don't want to get depressed. If we check it and we see that it's getting worse than the motor would have to come back out. If we check it and it stays the same then all is good. Right now we just want to live in the glory and keep our spirits up. We've taken that approach that "no news is good news" and with the way the motor is running and with the power we put down today, we'll be keeping our fingers crossed that the motor will live on for many years to come.
To say that today was refreshing is an understatement. Since last May 31st, I've had to deal with my driver's door getting backed into, the installation of new struts/shocks/springs, the removal/installation of a new heater core, the removal of the old motor and installation of a new motor, the removal/disassembly/reassembly/reinstallation of that motor (thrust bearing issue - the reason for this thread!), the hot starting issues, and the carburetor idle adjustment nightmare. I'm really hoping that 2015 can be a much better year for myself and my Cobra. I'm keeping my fingers crossed!
Here's a copy of the dyno sheet from this morning.
Here's a pic of the engine compartment that was enhanced by my new 347 air cleaner decal that I got from David Dowden. I'm luvin' it!
Pete Slaney
1979 Mustang Cobra
347/T-5/4.30's
11.49 @ 121.86
307 rwhp/278 rwt
12.38 @ 111.38
Nice Pete - glad you stuck with it.
1986 SVO Mustang - 1C
engine and bay looks amazing!! glad to see the bugs worked out
Pete congrats on the numbers! Pete and Paul, nice work on the tuning and the build!
The car looked and sounded great today and it was cool to see both you guys working together to fine tune it at the dyno. The motor runs awesome and I'm certain you will be just as surprised when you hit the track as you were at the dyno today!
Great work!
1987 Mustang GT
S trim. 10.85 at 128. stock short block and stock T5.
2002 Mustang GT convertible.
auto with 4.10's and tune.
2008 Viper SRT10 Coupe.
11.33 at 127 bone stock everything.
Awesome numbers..WOW!!!
Thanks everyone. It feels so good to finally have all the bugs worked out of it and to see/hear it running so good. I'll just keep my fingers crossed that the thrust bearing remains intact. We'll see how it goes as I get more mileage on it.
Pete Slaney
1979 Mustang Cobra
347/T-5/4.30's
11.49 @ 121.86
307 rwhp/278 rwt
12.38 @ 111.38
Congrats on an awesome dyno run Pete. It looks like you need to change your signature now.
Dave
1983 Capri RS Turbo
Dave,
Thanks! You're right. I'm off to do it now.
Pete Slaney
1979 Mustang Cobra
347/T-5/4.30's
11.49 @ 121.86
307 rwhp/278 rwt
12.38 @ 111.38
Reviving this from the dead, as it's been awhile since there was an update. Well, the motor has held together so far and I've been a happy camper as a result. It'll fry the tires from a roll at 40 mph - something my old 302 wouldn't do. I've got about 2,600 miles on it this summer without any major issues. The important news is that I took it to Lebanon Valley New York this past weekend so that I could run it down the track to see what it could do. I made it down the track 13 times between Saturday and Yesterday and boy does it want to go! My best pass was an 11.86 @ 117! It's not the 11.40's @ 121 that I predicted but I'm O.K. with that because I was able to drive it home without breaking it.
Pete Slaney
1979 Mustang Cobra
347/T-5/4.30's
11.49 @ 121.86
307 rwhp/278 rwt
12.38 @ 111.38
Nice pete! I keep cheering myself up by reminding myself that I beat you at Epping. Of course, that was because you went up in smoke at the line, but hey, a win is a win! I don't stand a chance next time. I may pick your brain about the shop in Seekonk- I need a few dyno pulls, and don't know anyone in N.H. I trust.
Yeah, you kicked the crap out of me at Epping. LOL! From what I understand, Pete at Performance Dyno in N.H. is really good as well. I've got a few friends I know that have gone there and got good results.
Pete Slaney
1979 Mustang Cobra
347/T-5/4.30's
11.49 @ 121.86
307 rwhp/278 rwt
12.38 @ 111.38
Where is performance dyno?
Edit-- guess I could just Google it, huh? Loudon, up by the lake. We ought to make it a cruise destination for the new england guys some time.
