Results 26 to 50 of 56
  1. #26
  2. #27
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Quote Originally Posted by Fordhorsemen View Post
    Found aerostar manifolds....they surprisingly Enough Are indeed Headers
    Should be a Direct Fit..... Will update
    Did you get the headers to work? I'm on the fence to try to find some and what years actually will work? We are going to do some head work to help flow without sacrificing too much original look (for starters).
  3. #28
    We'll To Be Honest.....After a Long Discussion with The Pinto Guys.....I Bailed On the Headers.
    Seems That Are to Many Negatives....... The Motor is a High Reving Engine.......Headers Will Make You Loose Low End Power. They Also Hug So Close to To Transmission it will Cause it to "OverHeat"?.....and with the Lack of Top Bolt.....it will Always Have Exhaust Leak......I Went with Duals off the stock Manifolds......
    Topic on Another forum:
    http://www.fordpinto.com/general-pin...ut-conversion/
    http://www.fordpinto.com/index.php?P...;topic=16695.0
  4. #29
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    The rebuild book I have doesn't state anything other than exhaust porting. We're thing duals for sure too. Thanks!
  5. #30
    Jan 2011
    China Grove, North Carolina
    You know, a friend of mine had a German Capri that had long tube headers on it, and he sold it to someone that is putting a 302 in it now. I'll check with him and see if he can still get them back, they may fit a Fox but we don't know for sure. That Capri had an even tighter engine compartment.
  6. #31
    Your engine just needs tweeking.
    My little 9.2:1 compression, 2-bbl 114 hp 2.3 Cologne V6 in my 1982 TF Cortina could do 118 mph after a big single exhast and cherry bomb resonator. Unlike your stock 2.8 US exhast system with its HEAPS better 3 out header, my stock V4 headers were inferior in every way to yours, yet it sounded so good. It started off with a C3 auto, ended up C4 Mustang 2.8, and got an IHI turbo and Impco carb for LPG.
    I got rid of it due to new job, family pressures and a new house.
    A 390 Vac sec 4-bbl and the exhaust mods you made are the only changes to kick start it. Then have your Duraspark re-curved to suit.
    I'd take the heads off, have them resurfaced or welded up to get 11:1 compression , and then go for Pinto 2000 power pack valves and a 280 degree Schnider cam. Then look at a certain kind of water injection.
    The Pinto guys (led by David Vizard with the Pinto SOHC 2.0), found total compression Ford engines can handle is huge if an anti detonation fluid is added. Early systems were above carb venturi Edlebrock Varijection, or above carb venturi washer bottle with two brass 16 thou holes or washer squirters with four failsafe systems.
    One simpler New Zealand devised system eliminates four fail safe systems by a restricted up draft water injection system (it needs no starter solenoid, no hobs valve, no manifold pressure sensor, and it allows static advance to be wound right up. I'm running 12.7:1 compression with 87 AKI fuel on my Mustang with one of these kits from http://www.dave-cushman.net/misc/mannject.html
    The Offy 4-bbl with all the above mods will be a stout day to day driver, and the extra power will mean the Porsche 930 Turbo style gearing will be endowed with Mustang GT power. You'll easily get over 190 hp with the following BEIGHT modifications.
    Breathing (4-bbl carb and Offy intake, better cam, better compression),
    Exhast,
    Ignition (Fat spark from the Duraspark II is ideal),
    Gearing (stock SROD wide ratio is fine when you start to get the engine past 5.0 2V GT power levels)
    Heads,
    Timing (Recurved ignition Static 20 - 22 degrees, full advance 32 deg at 3500, with anti detonation via Robert Mann Water/Methonal injection)
  7. #32
    actually if you install the right cam profile, you dont need anti detonation fluid unless you are running above 11.5:1 compression. however that cam profile tends to have a rough idle, and can be a bit weak on low end power.
    64 falcon
    66 mustang
    05 grand marquis
    dont just believe in miracles, rely on them!
    fordsix.com admin
  8. #33
    I Finally Got a Carb-Holley 8007
    Intake is @ Machine Shop Getting Glass Beaded
    Should Be Ready Tomorrow--Will Post Photo
  9. #34
    Intake Is Ready-Now if the Weather would Co-Operate
    BEFORE:
    AFTER-
  10. #35
  11. #36
    Oct 2011
    Nampa ID 83686
    WOW! That cleaned up great.
    Craig "IDMooseMan" Peters
    Buyer/Seller Experience Link
    Build Thread
  12. #37
    Got The Intake & Carb on as well as
    Removed A/C & Smog Pump today
    Thought I'd share a video of it Running real quick
    Still need to Plum Everything
    http://m.youtube.com/watch?v=_xyCFE_Y_Cs
    I also Put Shift Kit in C4
    Slapped Larger tires on Back
    & got a Cowl Hood few weeks back... I'll post better video & pics soon
  13. #38
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Thought I'd share a video of it Running real quick... I'll post better video & pics soon
    What were your reasons for removing the AC? I could see the smog pump. When we do this in the future sometime, I'll need to know which way I want to go and whether we can keep it on. Are you going to go with an electric fan set up?
    Can't wait to see the better video and pictures! Thanks for posting.
  14. #39
    The A/C Has never worked. I Could Have Very Well Left it .
    In Fact, I prolly Should Have....P/S Pump Flexes pretty Good When I Romp on it.
    Will have To make Some sort of Support.
    The Only Issue So Far Was that The bottom of Throttle Linkage Wouldn't clear Valve Cover
    So I Hacked it Off......Maybe Should have Tried a phenolic Spacer?
    But O'Well---I'm Just Winging It!
    Also I neglected to Buy the kit That goes With Offy Intake
    So I had to fab a bracket to hold throttle.
    I also had to purchase
    Holley part # 20-41 & 20-91
    For the Kickdown
    & Riser for Air Cleaner to Clear linkage
  15. #40
    Romp Clip: https://www.youtube.com/watch?v=EGffESmKync
    Rev Clip: https://m.youtube.com/watch?feature=...ient=mv-google
    I Have The Hardest Time Finding my own Videos so
    Putting This here For Safe Keeping.
  16. #41
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    I think whenever we get to putting the Offy and 4 bbl on my sons car we are going to be pretty happy! What exhaust system are you running? Stock type or performance? True duals or still the wye?
    Good idea on planting your links here for safe keeping too (for me too).
  17. #42
    I Ran True Dual Straight off The Manifolds......& Fortunately Emissions Test are Not Required in our State.
    Took a Few Shots of The Car Today.
  18. #43
  19. #44
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Sounds good! What diameter pipes and type of mufflers? Are they straight back from the engine or is there an H or X in there?
  20. #45
    No WYE-----I Left the Piping off the exhaust manifold for the WYE and Welded into that with the same size diameter exhaust Pipe
    No H or X Pipe-----Straight back to Turbo Mufflers
    The passenger Side rear Brake Line for 79' year model Seems to be very Problematic for anyone adding Duals-----I've heard too many Stories of Some1 getting exhaust done ....then not being Able to Stop as they leave muffler Shop!!
    I wrapped the brake line in Heat Sheath to keep the exhaust from burning it , in the event that it Somehow manages to touch ......( no issue yet )
  21. #46
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Looks good and sounds good. I can't wait to get to the point of having a running car again!
    I think I found a good way to get around the brake line issue. It was member ChristmasGT's idea that I saw first but it looks like it will work. I picked up a used 2.5" H-pipe and exhaust system to use once we are ready so I want to be sure there are no interference issues. It requires an '84 pickup flex line which is longer.
    http://vb.foureyedpride.com/showthre...=1#post1755976
  22. #47
    Sweet Deal! looks like an easy enough solution, Thanks!
  23. #48
    FEP User
    Aug 2009
    Vancouver BC Canada 20 minutes to border !
    I've built a 76 mustang 84 bronco II and a 85 bronco II all with 2.8 and all motors rebuilt. later blocks are better, upper thermostat is a must, headers will not fit in a mustang fox or a mustang II clearance the frame rail a touch in a bronco II and they will work. 1986 aerostar has a front serpentine belt drive with self reg alternator ear location specific to aerostar - this is an awesome swap. Duraspark is awesome and a regular 2150 runs great. 1974 heads are suppose to have best compression.
  24. #49
    Hi guys. I have a 1985 Ranger with a 2.8L V6. I am looking for manifolds. Someone can help me. Impossible to find for me.
  25. #50
    Sep 2008
    HILLBILLY HOLLYWOOD, Tennesse
    subscribed
    www.musclecardeals.com
