Results 1 to 3 of 3
    Default 84 v6 convertible starter removal
    I have the bolts out but cannot get the starter past the frame and the oil pan. It is away from the automatic trans. Does anyone know how to get the starter out of this area? I removed the cross support tie (only a few bolts) thinking that would give me a little room, but it is no help. I have turned it and tilted it, but it seems the only way is to remove the oil pan. On Youtube LateModelRestoration shows removal from a v8 hatchback which it just drops out - easy! Any suggestions would be greatly appreciated.
    FEP Super Member FM2NOTCH's Avatar
    Aug 2011
    Foothills of Piedmont NC
    possibly loosen both engine mounts raise the passenger side of the engine
    *FOXTOBERFEST* 2015 http://www.foxmustangrestoration.com/events
    85 T Top coupe 5.0 2R red, E7's, rpm intake, 4180 carb, 7.4 1/8
    83 CC capri 5.0 5 speed,black mesh wheels
    76 cobra II 302 auto black/gold, big cam 3 inch dumps- sold to a good friend
    92 coupe 5.0 5 speed -red
    92 Lx hatch 5.0 5 speed -black, 66 coupe 5.0 4 spd (project)
    87 Vert 5.0 AOD red stock as a rock
    " Are you sure you know what you're talking about? It kinda sounds like you know what you're talking about"
