Looks like its coming along real well. I love these cars! Its nice to see other Ford/Mercury cars. The interior is really nice looking. Looks like it belongs. Cant wait to see more pictures!
Love what you did with the car. As stated on your cable, weld a small piece of pipe in the hole for the cable to ride in too spread the load out. Just roll the edges on the pipe so the cable slides through it easily on each end.
I want to put an 87-up interior in my 80 notch. Any huge headaches that I can expect to encounter?
Sent from my DROID RAZR using Tapatalk
Well, I did it at the same time as swapping in the SEFI engine from the same car as the dash, so I just replaced my Zephyr wiring harness with the Mustang one and spliced in the lights and wipers. So, really I don't know what kinds of things you'll need to do to make the two harnesses talk to each other. Physically, mounting the dash is pretty easy. The bottom mounts are the same, and the top mounts you just bend down at an angle and drill some new screw holes.
I plan on swapping the engine too. Did you do AC or no?
Now I just need to find a donor vehicle. Let me know if you come across any rusted out 5.0's up north, haha.
I did not do A/C. It's too bad too, because it worked great with the original drivetrain in the car. I'd like to add it back one day though if I ever get around to it. I think there might be some problem making the evaporator lines line up. If I have to drill new holes in the firewall, then so be it, haha.
Will do. I know where there's an '02, but I think they want an arm and a leg for it. haha
Started prepping my new purchase, an Explorer intake, for paint! I'm guessing this thing must've been procured from a car that was hoodless and sat outside a long time. The paint is bubbled and there's a good amount of corrosion underneath. It seems to be cleaning up with just a die grinder and sanding discs reasonably well though! I also cut off the cable bracket on the end and started trying to shape it to the area around it. Felt good to get out there and get my hands dirty! it's still pretty dang cold here though. My air compressor wasn't very happy about all the use it got today!
Very nice Zeph! Me likey! I'm considering the explorer upper for the sleeper look! Should flow better than stock HO intake.
Well, the HO wouldn't bolt on to your GT40 lower anyway. I was thinking the same thing though, about using an Explorer upper with the Lightning lower when/if I go 351. It supposedly doesn't flow as well as a tubular, but that would be so cool! Maybe a subtly custom intake plaque that says "5.8" where it normally says "5.0".
plain clean and very nice
Thanks! Chomping at the bit to work on the thing! It got REALLY cold here again.
Really dig the interior swap!
I haven't been able to work on mine the last set of days off due to the sudden downturn in temperature, either.
I'm hoping we're on the final leg of cold weather...
Dan
1986 Mustang GT Cobra
Daily drivers
2012 F-150 Ecoboost Screw FX4
Woo hoo! Ordered parts today! Continental Extreme Contact DW summer tires, Tokico Blue shock & struts, MM k-member brace, new stock upper control arms and bushings!
can't wait can't wait can't wait!!
Still need to order coil springs ("B" springs or H&R Sports) new driver's seat foam, and some Ford low-friction ball joints!
Congrats on your parts order! Keep us updated!
Very cool! I can't wait to see how it looks on the SVO wheels.
Last edited by Mikethe80sFanatic; 03-31-2014 at 02:56 PM. Reason: Grammatical error.
-Mike-
83' LTD Brougham, 43k miles, 3.8 2bbl/Auto, Pretty much Stock/Original for now. DD.
88' Bronco XLT, 63k miles, Built 358W/C6..soon to be ZF5 swap, 4.10s. All-Around-Fun Machine.
96' Cherokee Country, 131k, 4.0 I6/Auto, 3in lift, Lots of Mods, DD/Off road Machine.
Me either. I'll post pics with its current "lift kit" suspension, and then after I put the new stuff in.
Ordered the ball joints today!
Argh, well, "new stuff" pics might have to wait a while. Stupid Tokico shocks and struts are on backorder indefinitely. Tires are on, but the weather is crap today. Blizzard. No, that's not an exaggeration.
And the ball joints were a dead end. Ford no longer offers the low friction ball joints, apparently. No one does.
What are the part numbers on the Tokicos?
Struts: HB3140 01
Shocks: HE3723
I hope those are right. I got them off the order confirmations. MM did have ONE shock for me, so they're sending it. Why would they just have one?!
Think I found a way to get the ball joints!
Zephyr 4x4 with SVO wheels!
They look like they belong on your car. Sort of gives it a little more of a sleeper look too.
Yeah! Definitely one of the benefits!
