Page 31 of 52 FirstFirst ... 21293031323341 ... LastLast
Results 751 to 775 of 1278
  1. #751
    Jul 2004
    Montebello, CA
    According to my Irish family side, G""d lookes after drunks, C~ and kids. But not if your a drunk C~ kid. Don't ask me how I know.
    Great work Brad. Bolt Extraction Expert. Awesome work brother.
    and Im half Irish....lol
    Past 4 eyes-
    U.S. NAVY 1980-2009
  2. #752
    Well this is about where we've been at for a good week.
    Trying to make sure I've got the cam right. After much discussion with some knowledgeable FEP-ers and Flowtech, we've settled on correcting my intake centerline gap (104 degrees dot to dot and 111 degrees 4 degrees retarded) with a new better quality timing set with more adjustability. I'll install that first chance I get, and then it shouldn't be any trouble getting us to that 107 degrees we're shooting for. I'm very happy we have a solution and can move on!
    Getting ready to yank the old engine out of the car so I can get at the oil pan, clean that up, and install it (and the new oiling system) on the new engine at the same time as I install the front cover. The new engine probably won't go in the car until I'm done working with the heads and the rest of the valvetrain. It's just easier to do it on the stand, and with the heads on, I can install the hooks these engines use for lifting. The school year ended this week, so I've got no more responsibilities working at the school, but at the same time, it's really hard to get delicate engine work done with the kids around.
  3. #753
    AAAAaaaaaaaaaaaannnnnnnnndddddddd we're lost again. I received my new Rollmaster timing set, and it came with this.
    WTF is that for? Will the directions tell me? Nope. Not a word. Turns out it's a brass washer that goes between the cam sprocket and the thrust plate because they are both "hardened" so you need something sacrificial in there to prevent damage. But wait, there's more! It comes too thick just in case of variance in manufacturing, so it's up to you to measure and make it the right thickness! How? Are you sure there isn't anything in the directions? Nope. Good luck, f***er! Better do it right, or your warranty's void!
    Seems like so many "upgrade" parts are like this! "Here buy this shiny new part, it will make your car go faster!" But then, once you have it, only then do you find out, oh wait, there's all these other parts and processes you need to make it work.
    My instinct with this build has been to go stock replacement wherever possible. I didn't necessarily know what I was going to run into each time I "upgraded" something, but it seems pretty universal what happens. Let's take roller rockers for example. With pedestal mount, you need to do all this f***ing around with shims and measuring to make sure they fit right. But you don't want pedestal mount, you want STUD mount! There are SO many more options with those! Oh, but wait, you need to take your heads off and spend all this money having them modified to accept the studs. ARGH! It's never just the one part! "Precision" where there wasn't meant to be any!
  4. #754
    Got some car time today, and instead of dealing with the stupid brass washer, I decided to yank the old engine.
  5. #755
    Jul 2004
    Montebello, CA
    about that brass (might be bronze) why cant you lay it flat onto sandpaper and sand it thinner to the thickness you need?
    Past 4 eyes-
    U.S. NAVY 1980-2009
  6. #756
    Yeah, I guess that IS what you do if you need to make it thinner. 'Woulda been nice if there had been some mention of that somewhere!
    But the cam dragon has been slain! The washer actually didn't need to be modified at all, and when I went to degree the cam with the new timing set, we are within 1 degree of the target intake centerline! VERY happy with that!
    Also, cleaned up and painted the oil pan.
  7. #757
    I think tomorrow I'll rent the harmonic balancer installer. I was getting the water pump ready to install today. I noticed that the old one had these kind of ground down bolts holding the metal plate onto the back of it. The new one had regular bolts.
    Since I broke one of the old one's bolts, I decided to grind down one of the new bolts to match. I could be crazy, but it seems like a good idea to me for the water pump to sit flush against the timing cover.
    Don't know what the water pump manufacturer was thinking there. "Our new water pumps don't seal!". Also, I have no idea what this thing is for.
  8. #758
    Jan 2004
    Olathe, Kansas
    Another thread was circulating about the backing plate bolts being too thick, What brand was the pump?
    Now stang-less.
    88 Cougar 5.0
  9. #759
    AC Delco. I chose it because it was one of the better brands they had on Rock Auto, plus it's aluminum instead of steel.
  10. #760
    Jul 2004
    Montebello, CA
    That looks like it "would" go onto the nose, where the fan bolts onto
    Past 4 eyes-
    U.S. NAVY 1980-2009
  11. #761
    Jan 2004
    Olathe, Kansas
    [QUOTE=ZephyrEFI;1907755]AC Delco.[QUOTE]
    Oh NO you didn't....!!!!!! That ford will reject it. LOL
    Now stang-less.
    88 Cougar 5.0
  12. #762
    Yeah, I know... It was gonna be a secret until you had to go and bring it up!
    That might explain why they're trying to sabotage your cooling system though.
  13. #763
    Oil pump, pickup and pan installed! Front cover and water pump are torqued down too.
    And i guess I rented the wrong balancer installer, so... that has to wait. And yes, I checked the oil pickup height.
  14. #764
    Installed the balancer and did some more teardown on the old engine. I'd left most everything on the lower intake (except the upper intake ) so I had to remove the heater pipe to get at one of the intake bolts. I went to clean up the rust where the hoses go on to it. I noticed some serious rust scale build-up at the back. I'd had a nagging problem with leakage there and I think that might be why. I think I remember rushing it the last time I installed this thing and not bothering to de-rust the pipes where they're close together and I couldn't get my die grinder in there. Let that be a lesson to the kids out there, I guess, haha. Problem hopefully solved! And that's good because new pipes are $100!
    Moving on, I got myself some assistance with the more exciting stuff.
    He was thrilled to be able to help me. Most of the time I'm doing something challenging or delicate, and I really just can't have him around, so this was a nice change. Got it down to a bare shortblock plus a few things I plan to throw in for the buyer.
    Heads are ready to bring to a machine shop to have the mating surface checked. I hate trying to find a machine shop. Seems like when you look in the yellow pages you get like 4-5 results nearby, but most of the time, it's just some suburban house or something when you look at it on Google Maps. Really? You got a whole machine shop in there? Don't think so. I absolutely hate talking on the phone, so I do as much research as I can before I commit my time to talking to these places. Unfortunately, with machine shops, that doesn't amount to much. They claim there's a machine shop at this address, here's the phone number, maybe the hours. That's it.
  15. #765
    Jul 2004
    Montebello, CA
    I know what you mean Brad, I have a set of AFR's (that I bought from......(a friend?)) so I went the machine shop at Team C and no more machine shop! but they recommended a shop named L and R auto...... so I hope they are ok... And good to see your young man helping with the build
    Past 4 eyes-
    U.S. NAVY 1980-2009
  16. #766
    Yeah, it's frustrating. I ended up just going to Napa. They have my heads now.
    I got some car time today though. I went to reinstall the shifter on my trans and put the bellhousing back on since I plan to install the trans as a whole unit this time. I decided to clean out and re-grease the Hurst shifter. It was pretty nasty in there. Presumably, it must've sat uncovered at one point. I have a new dust cover for it now though.
    Went to put the bellhousing on, and found out, you need to tip the trans WAY upward to get things to line up. After my tranny fluid bath, I decided to quit for the day.
  17. #767
    Jul 2004
    Montebello, CA
    oh, I never knew napa has a machine shop? and my good news is that I finally got my capri running, and I drove it outa my garage today to flush the radiator and add coolant. it purrs like a kitten. I was sooo scared to start it after all the wire work I did, it sat there for 2 weeks and all I did was to stare at it lol
    Past 4 eyes-
    U.S. NAVY 1980-2009
  18. #768
    Yep, some Napas do.
    Congratulations! That's a big moment! I certainly understand that anxiety though. I am the same way.
  19. #769
    Id like to give you each a huge plug.
    "https://www.ebay.com.au/itm/Tail-Shaft-End-Cap-Plug-FORD-C6-Transmission-Output-Yoke-Tail-Housing-Seal/310408376161?_trkparms=aid%3D222007%26algo%3DSIM.M BE%26ao%3D1%26asc%3D20180213162450%26meid%3Dc8c028 37e96e4a4cacd89640585ed628%26pid%3D100930%26rk%3D1 %26rkt%3D3%26mehot%3Dag%26sd%3D311328613655%26itm% 3D310408376161&_trksid=p2349624.c100930.m5375"
    https://www.classictransmissionsolutions.com/
    Its called carefull, guys.You each are a huge inspiration to me. Good work. "
    The plastic extension housing plug is found here Brad
    Tail shaft end cap plug
    CT Solutions
    CT6161
  20. #770
    Yeah... I keep thinking this will be the last time I pull the driveshaft off, so it would be silly to buy a plug now. How's that for wishful thinking? Just pulled the trigger and bought the plugs. Along with a tailshaft bushing and new seal since despite the recently replaced existing seal, it still leaked. This project is starting to snowball, but what else is new? I enjoyed this review on the plug kit on LMR
    Really, Dustin? Then don't write a damned review!
    My show deadline is fast approaching. I haven't had any car time for a couple of weeks, but now I'm going to have to chip away at it every day and get some solid car time days in if I'm going to make it. The show is two weeks away! At least I actually got to take advantage of an LMR sale. They usually start right after I make a big order.
  21. #771
    Got the heads back from Napa. So, at least I know I won't have to wait too long for them or anything. I've been pretty stressed about that deadline today. I decided to get down some of the trans-related parts I'd stashed around the garage in preparation for putting that all together today. And.... I can't find the bearing retainer. I'm POSITIVE I bought one, but it's nowhere to be found. Pretty p!$$ed about that. I'll try again tomorrow, and if I still can't find it, I guess I'll have to pay the stupid tax and buy another one. I don't need this right now.
    On to the hands-on work. Since I ordered a new output shaft bushing, I needed to take the stupid shifter back off, so I could take the tailshaft housing off. I'm about ready to swap that bushing now. Doesn't look like there's much to it. Oh, and I discovered why once you go to an aftermarket shifter, people generally leave the dust boot off.
    Oh, well. At least it can still do its job sort of. It's better than nothing.
    I was considering having my lower intake gasket matched, but it looks like there's a LOT of material that would need removing, so I doubt I could get this done in time to put the engine together for the show. So, that's disappointing too.
  22. #772
    Went to check Piston to valve clearance today.
    ... And, well, this happened.
    http://vb.foureyedpride.com/showthre...50#post1908950
  23. #773
    So yeah, I thought I would take a break from all that and go and swap the valve springs to the ones I got intended to work with the cam. That should be simple enough, right? Nope. They came with two different sets of valve retainer wedge thingies that put the retainers in different positions. You think I know which ones to use? F*** no. So, I'm stuck again. This is really getting old.
  24. #774
    I had misplaced the directions, and they had my answer. One set is for exhaust valves, and the other is for intake valves. Would not have guess that.
  25. #775
    Got most of the trans work wrapped up today. The new tailshaft bushing and seal are in. It sure was nice to have that new bushing driver kit I bought. But, I'm not so happy about having to put the tailhousing back onto the trans. It's a b***h on a T-5. You have to try and put the thing on straight while trying to get the detent thingy onto the shift shaft while trying not to let the reverse/5th gear shift mechanism get jammed out of alignment (it will NOT go on if that happens). For me, it resulted in the detent ball shooting out, rolling down the driveway and disappearing. So... got to order a new one of those. Remind me never to take that apart again.
    I also swapped in a steel front bearing retainer. I'd heard that the stock ones are aluminum, but if that's true, then someone had already done this upgrade on mine. The retainer I took off was definitely steel.
    The valvetrain continues to be a struggle. More on that later.
