Results 1 to 19 of 19
    Default 1982 Gas Cap: Anyone Have a Pic of Original?
    I am trying to find out what exact type of gas cap would have been on my 1982 5.0 from the factory. Can anyone assist with a picture?
    Thank you
    Here is one from eBay.
    http://www.ebay.com/itm/71-72-73-74-...ee002d&vxp=mtr
    http://myzephyrs.com
    Yeah, if I would have read the whole listing I would have seen that.
    Or if I had owned a 82.
    Dec 2002
    Greenville, SC
    Quote Originally Posted by RED 78' View Post
    Jim you are still the man! He is the best at making reproduction stickers. We are lucky to have him as a member!
    1979 Mustang Cobra 5.0
    2P Red and 1C Black
    Stock never goes out of style
    Proverbs 3:5-6
    My Mustang Story
    There are to screw holes with the remainder of the strap but curious to know what it would have looked like. Same as an 85/86/89 even? Gray/Black? Thanks
    FEP Super Member Kerry's Avatar
    Cortland, OH
    My 80 has the metal cap style cap, my 81&82 both had the plastic cap already. I have a used plastic cap with tether for sale in the parts section.
    http://vb.foureyedpride.com/showthre...t-the-Basement
    Current: 81 Cobra T Top, 79 Cobra.
    Past Toys: 1964 Falcon Vert, 1966 Mustang(owned twice), 70 Conv, 1978 Mustang II(first car), 80 Cobra, 81 Cobra, 82 GT T-Top, 85 GT 3,900 miles, 85 Predator/Twister 5S-0149, 86 Saleen 177, 86 SVO, 86 Mustang GT, 86 Mustang GT Vert, 87 Mustang GT, 89 Mustang Notch, 2003 Mustang GT Roush Clone, 2006 Mustang V6(Stainless Works LT's, MBRP cat back, 3.73's, tb, cai), and my favorite 2002 Mustang GT MPH 302 stroker, KB 2.2, TKO 500 640rwhp/591torque.
    FEP Power Member Bruce Mohacsy's Avatar
    Jan 2013
    St.Albert, Alberta, Canada
    Here is the one from my '82GT. Obviously the strap is broken and there is some over spray. (NOT from me!) my car came off the line in May of 1982. Hope this helps!
    Bruce
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Quote Originally Posted by Bruce Mohacsy View Post
    Bruce
    Was there a cut off that they switched between the metal and the plastic caps?
    I salvaged a newer (off an 87 Lincoln) plastic one with the strap to replace in my 82 and the three screws holding the nozzle flange in place do not line up with the two on the strap. I might have to presume mine originally came with metal one.
    Darran
    FEP Power Member 82stangracer's Avatar
    Apr 2010
    UPSTATE,SC
    Both of my '82 GTs have the double strap like pictured above. My standard roof is a 04/82 and the T-top is a 03/82.
    Chris
    Had
    Too many that I wish I'd kept!
    Have
    69 Mach 1 "M" Code
    82 GT 308(my 1st stang)
    82 GT T-top (a new beginning) Rebuild Thread
    71 Torino GT
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Quote Originally Posted by 82stangracer View Post
    I just looked at Bruce's pictures again and it looks like the strap goes around the filler neck not screwed into the flange like he one I picked. Are your like that?
    Darran
    Apr 2010
    UPSTATE,SC
    Both of mine screw into the flange.
Size:  55.9 KBName:  20130730_085214.jpg
    Chris
    Had
    Have
    69 Mach 1 "M" Code
    71 Torino GT
    Feb 2009
    Snohomish, Wa
    My 81 Capri has a screw in plastic cap as well.
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
    Jan 2013
    Two screws into the flange. I just got a new strap from an '80's thunderbird at the bone yard. The only diff was that it was light grey instead of black. I imagine an '80's Fairmont, etc. would be almost the same. The gas cap was plastic on the t-bird but it had different writing moulded into the cap. It was quite easy to pry off the black seal on the underside of the cap and put the new strap on my old Mustang cap. Easy peasy!
Size:  45.6 KB. Name:  image.jpg
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    I'm going to have to double check the one I got off an 87 Lincoln. The spacing on the bolts seemed different.
    Darran
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    The later 80's one I grabbed has different spacing. I actually think there were four screws holding the on, not three as our cars do
Size:  74.0 KBName:  IMG_3170.jpg
    Darran
    Well, I finally got my correct cap. A very belated thank you to all that helped. Great feeling to find the tough little parts.
    Aug 2003
    Villa Park, IL
    Not sure if Ford mixed and match the grey straps and the black straps for several years or if the change was for a specific year. The grey cap with black strap in my for sale ad was from a 1983 LX.
    http://vb.foureyedpride.com/showthre...-Eye-Fuel-Caps
    Horrible picture on my end but the strap is actually black.
