Once your cooling system/block starts developing rust, it can be a real bitch to get rid of. Having gone through this before on one of my early Fords, I would go back to a 50/50 mix and buy one of these drain pans to stick under the area that's leaking. http://s1.cdn.autoevolution.com/imag...your-oil_5.jpg It should capture what leaks so you can strain it through a paper towel and pour it back into the radiator. And, it will keep any animals from getting at it. I use mine to carry used coolant to the local recycling center.
If it doesn't quite fit under your car, drive your front wheels up onto a couple of foot long sections of 2 x 6's.
