Results 1 to 25 of 36
    Default hurst line lock install questions
    Just ordered a line lock for my mustang, and I can't figure out the best way to install it. All the diagrams that are on the instruction sheet, doesn't match my master cylinder in any way. I have the stock master, and proportioning valve. Does anyone have photos of their setup?
    FEP Senior Member Johnny's Avatar
    Oct 2012
    Tuckerton, NJ 08087
    It's pretty much a straight forward install. Out of your portioning valve (the line that goes to the front brakes), install a new line and connect that to your new soleniod (in) out of the other side of the solenoid (out) that line goes to your Distribution Block for the front brakes. After that, wire it, bleed it and you're done. Happy burn out time!!
    1966 Big Block Sport Fury.
    I have the Summit Racing one but its the same thing. You can kind of see how I have it plumbed in this picture.
    Name:  Engine Paint 008.jpg
Size:  75.5 KBName:  5.0 Work 037.jpg
    FEP Power Member black1980fiveoh's Avatar
    Jun 2006
    British Columbia Canada
    it is easier than you think. Sorry I don't have a good picture for you.
    1980 Cobra http://www.cardomain.com/ride/2364382
    11.82@115 mph - 2015 - retired due to cancer
    1981 Cobra
    reborn with a lot of new go fast parts and time to make it look pretty
    11.80 @114 mph - 2016
    The supply for the solenoid comes from the master cylinder or the proportioning valve?
    Quote Originally Posted by Johnny View Post
    So, I'm gonna remove the line for the front brakes from the distribution block, feed that into the "IN" port of the solenoid, and then send that line back into the distribution block? I used the wrong word in my original post, I don't have a proportioning valve, just the master, and the distribution block
    FEP Power Member MAD MIKE's Avatar
    Jan 2009
    San Leandro, Ca.
    Quote Originally Posted by 4EYES31 View Post
    If you have the stock combination valve, then that contains the proportional valve inside for the rear brakes. It is preset from the factory, there is no adjustment. There is also the differential warning valve, and the distribution splitter block, all wrapped into one chunk.
    Splice into the primary circuit which is closest to the booster.
    MC > Line Lock > Combination valve. Wire it up and try some burnouts.
    -Michael
    '79 Fairmont 5dr 'car guy safe' MM Tech Tips StopTech Brake Bias StopTech White Papers
    Does anyone have a clear photo on how they installed their line lock, I can't make heads or tales from the other photos
    Also, I have looked at several photos of other foxbody installs on google, and my master cylinder is different than the others. my MC is all steel, even the reservoir, and the MC i see have a plastic reservoir. Does that make any difference? I doubt it does, but I figured I'd ask anyway.
    Oct 2012
    Tuckerton, NJ 08087
    Like I was saying before, it's straight forward really. Look at the pic. If yours is different then this, take a few pics of your setup and post them here. I can walk you through it.
    Yeah, I'm gonna take some pictures tomorrow, because my system doesn't look like that.
    Oct 2012
    Tuckerton, NJ 08087
    What year is your car?
    86 lx.
    Here are the pics of my system
    sorry for the bad pics, but the line for the front left brake is at the bottom, in the back of the block, and the RF is at the very back of the block.
    FEP Super Member FM2NOTCH's Avatar
    Aug 2011
    Foothills of Piedmont NC
    all you have to do is put it in the line to the front brakes between the mc and prop valve and wire it up, you'll need to add a brake line from the line lock to the prop valve, so simple a caveman could do it
    *FOXTOBERFEST* 2015 http://www.foxmustangrestoration.com/events
    85 T Top coupe 5.0 2R red, E7's, rpm intake, 4180 carb, 7.4 1/8
    83 CC capri 5.0 5 speed,black mesh wheels
    76 cobra II 302 auto black/gold, big cam 3 inch dumps- sold to a good friend
    92 coupe 5.0 5 speed -red
    92 Lx hatch 5.0 5 speed -black, 66 coupe 5.0 4 spd (project)
    87 Vert 5.0 AOD red stock as a rock
    " Are you sure you know what you're talking about? It kinda sounds like you know what you're talking about"
    Quote Originally Posted by FM2NOTCH View Post
    Hurst instructions do not recommend doing it that way, although, I may do it that way. They want you to add the line lock after the prop valve, which I would probably use the port for the LF brake, run a new line from there, feed it into the solenoid, remove the RF line from the block, cap the port in the block, then tie the two lines together with a tee fitting. That's what they suggest, but I don't see any reason why it wouldn't work the way you suggested.
    Aug 2011
    Hurst instructions do not recommend doing it that way, although, I may do it that way. They want you to add the line lock after the prop valve, which I would probably use the bottom line for the left front brake, feed it into the solenoid, remove the RF line from the block, cap the port in the block, then tie the two lines together with a tee fitting. That's what they suggest, but I don't see any reason why it would work the way you suggested.
    more than one way to complicate things, the line lock on my 85 is installed as I described, been on it since the mid 90's
    Is your brake system the same setup as mine? If so, I'm definitely gonna set mine up the same way.
    Aug 2011
    mine has all stock 85 parts, the line lock came from summit, one line in one line out, I have it wired to the horn button, of course the horns have neen removed.
    Oct 2012
    Tuckerton, NJ 08087
    The way FM2NOTCH said to run is the way you should do it. You won't have any issues. Let us know how it goes.
    Follow the directions in post #7. This is the correct way. The year of your car or model of your m/c will not matter.
    You DO NOT want to install the line lock on only one front brake.
    Jack Hidley
    Jan 2009
    San Leandro, Ca.
    Quote Originally Posted by Jules Winnfield
    "mmm hmmm, this is a tasty burger..."
    Quote Originally Posted by MAD MIKE View Post
    "Say 'what' again."
    -Michael
