My sons car was running fine Saturday, took it to work, parked it, came out of work and went to start it and it caught for a tiny second but then never started.
Here is what I know-
- Distributor was in need of replacing as the bushing were shot and it squeaked, was hoping it might be the PIP and then be done with it, but its not it. Another distributor is installed and no go.
- Will run on ether only as long as I spray.
- 38lbs of fuel pressure and I hear the pump turn on, tested at the schrader with a Fuel Pressure Gauge
- Coil wire is producing spark as I stuck a screw driver in the end of the wire and put it near ground.
- Pulled off wire 5, stuck screw driver in and held near ground, spark upon rotation.
- took off an injector connector and it connects to ground upon key turning forward.
I ran codes and we already know the transmission needs to be flushed and shutter fixed as it shutters, so that is some of the codes but the damn thing goes so fast I am having a hell of a time keeping track of what code it throwing, here is a video. http://youtu.be/DMEEjWsryFU
Any help would be appreciated, this is his main transportation right now and I need to get him running ASAP
Keep in mind, I am no pro and handle me gloves lol
