I ran the car fax Shows delivered to Govt 5/1990 sold at auction in texas in 6/5/2000 with 16,788 miles it has only had 3 owners. it currently has 69,351 miles and the documentation to prove it
VIN
1FA = Ford vehicle manufactured in USA
C = active belts, driver-side airbag
P = passenger car
40 = Mustang LX 2-dr coupe
E = EFI H.O. 5.0L V8 engine
7 = VIN check digit
L = 1990 model year
F = Dearborn Assembly
191614 = 91,614th 1990 Ford scheduled for production at Dearborn Assembly
Door Tag
Date - 05/90 = May 1990 scheduled build
F0140 = 140 lbs front accessory reserve load
R0183 = 183 lbs rear accessory reserve load
Exterior Paint Colors - MK = Twilight Blue Clearcoat Metallic
DSO - 83 0113 = Government district sales office (83), 1990 model year special order # 0113
Body - LX2 = Mustang LX 2-dr coupe
Mldg - X =
Int Trim - AB = cloth seating, low-back front buckets (A), Crystal Blue interior color (B)
Tape - P =
R - 9 = electronic AM/FM stereo radio with cassette tape player
Ax - M = 2.73:1 axle ratio, Traction-Lok limited slip differential
Tr - T = AOD transmission
RR = front springs
SS = rear springs
Buck Tag
0284 = rotations # 0284
LX = LX model/trim level
ET = EFI H.O. 5.0L V8 engine (E), AOD transmission (T)
AC = manual air conditioner
HB = heated backlite (rear defrost)
MK = Twilight Blue Clearcoat Metallic exterior paint color
WD = power side windows (W), power door locks (D)
PS
AB = cloth seating, low-back front buckets (A), Crystal Blue interior trim color (B)
LF = 1990 model year (L), Dearborn Assembly (F)
0514 = May 14 scheduled build
830113 = Government district sales office (83), 1990 model year special order # 0113
2
50
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
Unless you got paperwork with the car that proves which government agency "owned" it, nobody I know of right now knows how to find that out. Closest you're going to get is that is was ordered by the US GSA (United States General Services Administration).
I can say that your VIN is part of a large group of 86 consecutive P40E (Mustang LX 5.0L 2-dr coupe) VINs, from LF191606 through LF 191691. There have so far been four different DSOs discovered in that group: 83-0113 (LF191612 and LF191614), 83-0114 (LF191640), 83-0117 (LF191615 and LF191656), and 83-0115 (LF191668). There may be one or more additional DSO(s) in that group.
I have and continue to work with the admins and moderators at specialservicemustang.net on the VIN Project there and it looks like Bill (28HopUp here and there) has already put the pics you posted on it's own page in the project.
http://www.specialservicemustang.net...ead.php?t=3239
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
If you end up finding a way to research or get info on former GSA SSPs, please let the SSP community know!
I will pass along any info I get. thanks for all the work you do!!! We don't say thank you enough to cover all of the research you do!!! Thank you!!!!
