Anyone know where you can get the fasteners for the kick panels?
My facebook:
http://www.facebook.com/ahgrafx
Artwork:
http://www.addictedtopixels.com
http://www.addictedtopaint.com
My local hardware store carried much of what I needed,otherwise LateModel Resto carries them.
http://www.latemodelrestoration.com/...Panel-Clip-Kit
OMR
'86 Med.Canyon Red Met.(original paint) T-top,5 speed,3.55 rear,MAF conversion(A9L).MM adj. RLCAs,T/A,Panhard Bar,and adj MMRSB-3,rear T/A springs 375#-440#,MM C/C plates,MM 1.125" dia.swaybar,STB,4pt KMB,FLSFC's,'03 Cobra rack-n-pinion w/ Saginaw pump conversion.Bilstein MM coilover conversion and A-arms,front spring rate:250#.
your local hardware store carried these?
My facebook:
Artwork:
Yes,in the fastener section with all the pull out drawers.They had quite abit of the automotive stuff on hand,the proper panel screws and a large assortment of push pins.I did have to go to another store to find the long push pin for the drivers side,but otherwise yes.
OMR
My hardware store has them as well. If you just want to get them without a bunch of searching just order them from any mustang shop.
Keith formerly STLPONDS
'79 V8 coupe in the works!
ahgrafx Get two of the long one,I bent one trying to get it in.Mine was hard to push in and it bent in the center.Good thing i had extra. I got mine at lmr,They came gray had to paint them tan,No bid deal though.
$10 just seems high for those then after shipping especially. Is one long and one shorter? It has been 8 years since I took the panels out so I have no idea what they looked like because I lost them, moved around too many times in the last 8yrs.
thanks for the help guys
My facebook:
Artwork:
Yes, you need one long and one short.
Cheers!
Mike (TopGear85)
Have:
Had:
79PC-San Jose #2890
90GT-Oxford Wht,5spd
one long and one short for the pass and driver side or just one long for driver and one short for pass?
My facebook:
Artwork:
Just one long for the driver and one short for the passenger.
Cheers!
Mike (TopGear85)
Have:
Had:
79PC-San Jose #2890
Thanks top gear, I think I have the short one, can someone give me a measurement for the long one?
My facebook:
Artwork:
wonder if home depot would carry them?
My facebook:
Artwork:
