I'm hoping to go to the track wed and I have a set of used BFG DR's. So what pressure would you start off with? I know a lot of variables but trying to get a base range.
What range of air pressure should I start off with using a "used" 275-60 -15 BFG DR? Car has a mostly stock suspension out back with a full drag setup up front (upr kmember, 90/10, and 175 coil overs). I was leaning towards 18-20 psi???
