Got some work done this weekend...
Painted the bell housing:
Fabricated and installed sump on gas tank.
Black Betty is home. My buddy dropped the car off tonight. We put it on the lift and installed the line lock and brake lines. Also we touched up a few welds and while it was up in the air. My step son played gopher tonight and got to drive his first mustang as we pushed it into my garage sitting in his own racing seat (folding chair).
So I gotta ask everyone a question...
Do you get offended when someone calls your fox a rust bucket?
My buddy called her a rust bucket last night, which she does have some rust but its all surface on the bottom. Infact most of the bottom still has the factory primer and paint.
His comment has been ringing in my head all day...
I get it once in a while. Your vision has to be strong enough that you shrug off the criticism. You have to SEE what others can't! Now that my powertrain is bolted in along with an independent rear suspension, others can see where I'm going with my Daddywagon project and I don't get the really negative comments anymore.
No work on her this weekend... too much snow and work. Been pulling alot of hours at work lately like 28 hour shifts. ALOT of overtime coming my way.
Well it's been a while since I updated anything on the thread... Mostly because I haven't had time or money to do anything to the car.
We went down to the Engine builder's shop on Wednesday night and through around some ideas. So far we have a couple things nailed down.
He had the block blasted and baked and everything looks great. The crank looks like it can stay standard bearing sizes. He cleaned up the weights and the casting marks on the crank. He's chamffering the oil holes in the crank and a little more polishing work on the journals as well as rebalancing it.
He has a set of Sealed Power .030 over pistons and rings that are sitting there brand new. He's going to put them in after the block and heads are magnafluxed. Also we will be running SCAT rods.
Once the heads are cleaned up and he's done a 5 angle valve job on them, they are going to a friend of his who is going to port and polish the heads.
We talked about what intake to run, he wanted to try out a Parker Funnel Web intake. If not we will be going with an Airgap. Still trying to decide on that.
Funnel web is really cool but I'm a little worried that we may not be in the power band to use them. From what I've read they are like the Victor Jr. from 0-4500 RPM then from 4500 to 7500 RPM they blow the Vic's out of the water. Builder says we would be redline at 6-6500 RPM.. I'm a little worried we would be leaving alot of power unutilized. So I'm trying to decide what to do... Go with the Airgap and call it a day or have the rest built to handle the 7500 rpms to utilize the funnel web. Ultimately it comes down to how much more it's going to cost.
Got to work on the car a little today. I added the rear hood pins and installed the right front fender moulding.
Well it's been a while since I posted anything up here regarding the car.. Things have been getting in the way of working on her. I recently got a set of MAC headers off a friends rebuild project that I'm cleaning up and also picked up a SN95 front end setup from him as well. Hopefully I will have a little more time and money to work on her in the coming year. Engine has been bored and honed and the builder is assembling the bottom end and balancing it. Hope to get down to him in the next couple of weeks and get some pictures of the engine and put them up here.
Good build. Hope you smoke that Trans Am.
Build continues... We had quite a few setbacks that caused the build to stall for several years. We now have a garage and a place to work on the car. After losing two engines to an engine builder who disappeared with our engines. We now have a 302 bored .040 over with 351 heads and a parker funnel web intake. Lower end is assembled and the heads are on. We are working on getting the push rod length and then final assembly of the top end.
Keep on keepin’ on! The payoff is just around the corner when you get to drive it. I built my project in my driveway and that first startup and that first drive are the greatest feeling.
