I finally made my way over here to check out the 4 eye site.
I always wanted an '86 GT and I found this one a few months back with a blown headgasket for a good price. I tore the motor down and began making it what I wanted.
I installed ARP Head studs, Cometic MLS gaskets, Had the AFR 185 heads freshened with valve job and new stainless valves, New Trick Flow R-series Upper/lower and 75mm Trick Flow TB and EGR Block off plate. I studded the intake and headers and put on a nice set of Comp cam's valve covers and the intake required a 1 inch spacer. It has a 5 speed and 3.73's and BBK Long tubes with 1 chambers and E.T Streets.
I have a brand new Vortech V-3 Si Trim in the box waiting to go on but I want to get the bugs (vacume issues) out of this car first.
What do you think it will run on motor?
