Finally got my junk to the track Saturday. I've been out of country for work and desperately needed a test session before the NMRA race at MIR next weekend.
Was planning to work on a 12.00 set-up for True Street. Had a bit much in the launch RPM and was a bit conservative (high) on the tire pressure for fear of having a bog for the first pass ... Well, I blew the tires off, went 1.85 60' (usally 1.60 ish) ... car still went 11.89 at 118 MPH. Was happy with it for what I had in it.
Took 200 rpm out of the launch, took the tires down to 13.5, and went back for a 2nd pass. Put it on the two step, dropped the clutch and BOOM ...
New one to me, it blew up the slip yoke on the drive shaft ... I knew it wasn't going to be good as the tailshaft seal was laying on the track along with a few aluminum bits ... was still hopeful because there wasnt a lot of oil (just about 10 drops). Pulled the trans this morning and extracted the rest of the slip yoke ...
And got a look at the tail shaft housing ...
A little bit of luck, pulled it apart and the main shaft was still okay. This is a G Force with their main shaft, it it was damaged it would have been a little set back to my plans for a while ($$$'s).
Got a spare hounsing on, and it's ready to go back in the car tomorrow ...
I need to order a driveshaft and a few other bits, some chance I can still make MIR
FWIW, the car shut off when it did this, I thought that was a bit odd, but whatever. Strange enough, it wouldnt start after I got the shaft out either. We messed with it a while before someone suggested I check that fuel shut off thing ... sure enough it hit so hard it tripped the inertia switch
