Results 1 to 13 of 13
    FEP Member 82CapriRS's Avatar
    Apr 2003
    North Scituate, RI, USA
    Default annoying sound from my clutch?
    I just started driving w/ the windows down again, so I don't know how long it's been happening.
    I get this high pitched "chirping" (only way I can describe it) when the car is in gear.
    Not too loud, but annoying with the windows down.
    If I just gently tap my foot on the clutch pedal, it stops until I change gear again.
    Is it a stretched cable???
    Thanks,
    Jim P.
    Cars:1982 Mercury Capri RS, 5.0 HO
    1973 Ford Maverick, 250 L6, C4
    1977 Ford Maverick, 250 L6, C4
    FEP Senior Member svo6's Avatar
    Mar 2004
    Deforest, Wi
    Probably throw out bearing
    408 C.I.-Sleeper
    Quote Originally Posted by svo6 View Post
    I agree with that...
    My Previous Stangs:
    86 GT, t-tops, 5 speed.
    87 GT, sunroof, 5 speed.
    88 GT, sunroof, 5 speed.
    89 LX, Sunroof, Roller (project)
    90 Coupe, LX, 2.3, 5 speed.
    FEP Power Member wman24's Avatar
    Mar 2009
    Medford, NJ
    Do you still have factory cable and quadrant? Adjustable ones set with freeplay on the throwout bearing will chirp.
    FEP Senior Member 4EYED85's Avatar
    Mar 2012
    Round Rock, Tx
    Quote Originally Posted by wman24 View Post
    Its one or the other, you could put a good aftermarket quadrent and cable on it, which IMO it needs anyway. If that doe not fix it, its the throw out bearing
    Apr 2003
    Clutch and throw out bearing less then 1000 miles
    1982 factory clutch fork and cable.
    Ordering new cable now!
    Thanks guys!
    Mar 2009
    Medford, NJ
    What brand is the bearing? Not to sound like I'm beating the drum for ford parts but some of the tob that come with clutch kit are not that great. I have one new a new one that came with a RAM clutch on the shelf now, put a ford one in and called it a day.
    One the fox mustangs the TOB is preloaded against the clutch diaphragm fingers, it alway spins, a low quality one will wear out pretty quickly.
    What did the ford throw out bearing run you?
    Mar 2009
    Medford, NJ
    They are not cheap, iirc around 50 bucks.
    But if it saves you from pulling your trans every 6 months it's worth it
    Apr 2003
    I used the one that came w/ the RAM clutch kit.
    I really think it's the cable though, like I said, if I bearly apply pressure to the pedal, taking up the 1/8" of slack before the pedal pulls the cable, it stops.
    Mar 2009
    Medford, NJ
    Quote Originally Posted by 82CapriRS View Post
    It very well could be, just throwing out suggestions. I hope a cable fixes it, a lot easier then dropping the transmission.
