OK so yesterday I fired up my 84 Capri 5.0 for the first time since about mid-January. When I put the car away back in November I had just reset the idle mixture on the then-new edelbrock 1406 carb. It ran smooth and idled at about 850 perfectly. When I ran it to circulate coolant after swapping the radiator in January it ran perfect. Then I discovered a coolant leak between the timing cover and block. I just fixed that. Now the car will not idle at all. Get it below 1200 RPM or so and it instantly cuts out and dies. I'm guessing it's something with the carb but it was perfect before. I drove it around my neighborhood and as long as I kept it around 2 grand it ran fine, plenty of power. Push in the clutch, dead. I'm a bit puzzled.
