Like the title says. I get the car in to high gear and get to the 1100 foot mark and the engine goes flat, but its not every pass, its only about 6100 rpm. My engine is EFI, 347 ford with Roush 200 series heads, 10.5 compression, hdyralic roller cam, trick flow track heat intake, 32 pound injectors backed by a AOD camshaft. Any ideas would be greatly appreciated. Fuel pressure is good, oil pressure is great. New plugs gapped at 35. new cap and rotor.
