Take a look at the photo below:
http://www.maximummotorsports.com/co...MRLCA-1_LG.jpg
Draw a line from the front bushing pivot axis to the rear bushing pivot axis. Measure from this line to the top of the spring perch on the control arm, at right angles. It is the length of this second line that determines what affect the control arm has on the ride height of the car, assuming the bushings don't compress, thus changing the length of this line. Note that we have machined the control arm tube so that the spring perch is sunk down into the control arm tube. This was done to make sure that the control arm does not change the ride height of the car compared to a stock control with good bushings.
The control arm has a spherical bearing in one end. This does require a fair amount of torque to rotate when new. It will easily rotate under the torque supplied by the weight of the car. The other end has a three piece polyurethane bushing. This rotates fairly easily by hand.
For the MM control arm to raise the car 2" in the rear, the spring perch would need to be 1.33" higher than the stock perch. You can lay your stock control arm down and see that the MM control arm is clearly not 1.33" different.
If your ride height measurements differences are based on the same model of springs on a different Mustang, you have introduced many variables into this that are going to affect the results.
I would also double check that the lower end of each rear spring is pointing in the direction shown in step 22 of the installation instructions.
