Results 1 to 7 of 7
    Default procomp ignition
    i have an 85 gt and just added a procomp dist 8000 series and a multi spark pc6al cdi ign box and cant get it to run right.its like its a tooth off but for some reason i can not get it to go back a tooth.i can get it to run after cranking the dist one direction but when i shut it off i have major starter drag.i bring it up to top dead center i believe with 0 being on the pointer and harmonic balancer ,am i 180 out or what please help
    I have seen on other sites where many people have had problems with the procomp stuff. Most of the issues were with the ignition box not working properly.
    Welcome to FEP!
    Sorry double post.
    Oct 2011
    Nampa ID 83686
    Welcome to FEP. If it were me, I would remove the spark plugs, rotate the engine to TDC on the #1 cylinder, make sure it's on the compression stroke. Then pull the distributor cap and check the rotor position. This will tell you if you're 180* off or not. Make your adjustments as needed from there.
    Craig "IDMooseMan" Peters
    Buyer/Seller Experience Link
    Build Thread
    Top dead center on compression stroke, rotor will point to the number one cylinder on the cap. You can leave the distributor where it is, as long as there is no physical interference between the distributor and the manifold, and you can move distributor enough to set timing.
    You can just start with where the rotor is pointing for number one cylinder. Then continue around the cap with the correct firing order. No reason the distributor has to go in the exact spot it came out of. I used to sweat pulling out a distributor, but it really is not a big deal. Not as complicated as some people make it out to be.
    Jess
    Previously owned;
    FEP Power Member blackgt85's Avatar
    Dec 2005
    Sussex, WI
    IMHO, you would be better off removing the ProComp stuff and putting your original Duraspark module and distributor back in.
    Why did you remove the Duraspark in the first place? Do you have the need for a hotter spark than the Duraspark could provide? What other mods do you have done to your car?
    Justin
