Can anyone show me where the wot cutout relay location is Please? My AC stopped working near the end of last year(sept). Checked and bypassed the pressure switch, checked the clutch and wot switch and all is good.
Go0fY
Go0fY
What year are you working on?
1986 Notchback, Recently repainted Light Regatta Blue(3J) and getting put back the way it should be. It had a 3.8 and a C5. Now it has a 5.0 and a T5.
1985 mustang gt
Passenger side fender tower facing firewall.
http://i129.photobucket.com/albums/p...ustang_002.jpg - Sleeping Beauty!
1985 Mustang GT: Trick Flow Heads, FRPP z303 Cam, 1.7rrks, edelbrock rpm intake, Holley 650DubPump, K&N Filter, Mac equal lenght headers, Mac Off-Road h-pipe, Flowmaster 40 Series mufflers, Msd 6al ignition, Msd Blaster 2 Coil, Msd Billit Distributor, Short Shifter, racing pullys, 8.8 rear end, 3:73 gears, no traction, and bad shocks.
It's been a while, IIRC it's actually under the driver side dash.
Use the search function...
-j
_________________________________________
1984.5 Mustang GT: org. 5.0, 5spd, 3.27's;
GT-40's w/93 exhaust; t-bird TC brakes....
It's behind the passenger side dash above the glove box. It is attached to the metal frame of the dash.
1985 Mustang GT Convertible
Hi I am confused what I do I am new here
Australia Immigration
Ok thanks
One says strut tower, another says drivers side dash,
then another one says passenger side dash above glove box
So I will be looking above the glove box first to start.
Thanks again for your replies
Hi
If your car is a 5.0 with 4bb, than it is located on the carb. On the carb, front left corner of the carb, there is a dash-port with two wires connectors off it. The dash-port kicks your throttle a couple hundred rpm. when your a/c is inguaged. There is a micro-switch that at full throttle will disenguage the a/c.
Follow pink/blue wire from pressure switch on dryer.
My Bad!!
Front right corner of the carb when standing in front of car!!
Sorry for the confusion.
85stang is probably more correct since I remember he messed with this relay before; thus passenger side of the dash as he said. ( I knew it was inside rather than outside). Now that is for the Relay, that times how long the AC cuts out for once the Switch (on the carb) is activated.
Clearer?
-j
