its definetly vaccuum. I held my hand up to the oil neck and it was enough vaccum to suck the palm of my hand to it. also as a side note, the engine will almost stall when the oil filler cap is off. the rpms will surge and die, surge and die, but not cut all the way off. These valve covers are off a f-150 truck .. The oil filler cap is raised up off the valve cover with a little pipe.. This pipe has a t off it. I plugged that cap. I think it was about 5/8 Maybe I need a breather there or something? No clue.
yeah and I never knew that would be a problem but i will delete the one on the valve cover and plug the bung on the bottom of the intake that goes to it. I'll be down to one pcv then. The gauge I have is a brand new autometer electric water temp gauge with a brand new sender made by autometerOriginally Posted by TWR2003
