Like the title says, which one? I have already chased all of the holes to make sure they are clean and I want to make sure thay come out if I ever need to remove them.
1986 Notchback, Recently repainted Light Regatta Blue(3J) and getting put back the way it should be. It had a 3.8 and a C5. Now it has a 5.0 and a T5.
none of the above. use thread sealant.
cale
Yep. Thread sealant- and the Teflon in that is an effective anti-seize, so two birds with one stone, so to speak.
I have always used anti-seize, but I am open to trying new things. Is there a brand in particular that anyone could suggest?
This stuff works great.
http://www.amazon.com/Permatex-80632.../dp/B000HBNTGY
That is exactly what I use, and it can be had at any parts store if you do not order on line. A can that size will last about a hundred years. I always used to use neverseize, but had my mind changed.
I use anti seize on the shaft so it doesn't seize to the pump and thread sealer on the threads.
1985 Mustang GT 5speed LRB with Ford Racing M-6007-X302, Performer RPM, Holley 670 Avenger carb, BBK headers with H-pipe, B&M short throw
1986 Mustang GT (parts car)
1986 LX Coupe 4cyl, 4speed, LRB
I will pick some up next week. Would this also work on intake bolts?
I get mine at home depot, plumbing depatment
85 GT T-Top, GT40P Explorer longblock, Holley 600cfm carb, Edelbrock Performer RPM Air Gap, TFS Stage 1 cam, Ford racing gt40p shorty headers.
DarranOriginally Posted by BLUECRAPI
I've always used Permatex Ultrablue, Ultrablack or Ultracopper. Keeps the threads from ever rusting, acts as a thread sealant and an anti-seize.
My photo website:
http://www.twilightphoto.com/
